valve lash for b16 with ctr cams?
Old Sep 17, 2006 | 08:50 AM
turbotime's Avatar
Default valve lash for b16 with ctr cams?
i was wodnering what are the valve lash specs i should run i and e side for a b16 with CTR cams? Just teh standard or is it a lil different cause they have more lift...?
Old Sep 17, 2006 | 09:20 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: valve lash for b16 with ctr cams? (turbotime)
0.006 intake 0.008 exh.
since my smallest feeler gauge is 0.007, i set all my b series vtec cams at 0.007 did that on my mazworx cams and they are fine.
Old Sep 17, 2006 | 10:09 AM
Hybrid96EK's Avatar
Default Re: valve lash for b16 with ctr cams? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">0.006 intake 0.008 exh.
since my smallest feeler gauge is 0.007, i set all my b series vtec cams at 0.007 did that on my mazworx cams and they are fine.</TD></TR></TABLE>
Wouldn't reccomend this. The intake spec is .006 and a 10th, while it may not seem like much, could cause problems. Although I would agree its better to go too loose then too tight. Get a good set of feelers. Will-go-won't-go's are my personal choice. Highly accurate.
Old Sep 17, 2006 | 11:02 AM
turbotime's Avatar
i got some craftsman feelers they go out to .00x so based on that should i just go .006 and .008 or no?
Old Sep 17, 2006 | 12:00 PM
Mr. Badwrench
Default Re: valve lash for b16 with ctr cams? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't reccomend this. The intake spec is .006 and a 10th, while it may not seem like much, could cause problems. Although I would agree its better to go too loose then too tight. Get a good set of feelers. Will-go-won't-go's are my personal choice. Highly accurate.</TD></TR></TABLE>
where do you see 0.10? .1 is a tenth. .001 is a thou and the leeway is more than that. if the spec is 0.006 and then a tenth would be 0.106
and i didnt say that.
0.007 is fine.
Old Sep 17, 2006 | 12:02 PM
Hybrid96EK's Avatar
0.007 is fine. </TD></TR></TABLE>
Excuse me for making a mistake in the way I quoted the decimal. My bad. Run your valves to .007 then. I don't know a damn thing.
Mr. Badwrench
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">i got some craftsman feelers they go out to .00x so based on that should i just go .006 and .008 or no?</TD></TR></TABLE>
to do them correctly, yes. 0.006 intake and 0.008 exh.
the reason i do mine like that is, like i said, my feelers which are go no go, start at 0.007.
Old Sep 17, 2006 | 12:06 PM
Mr. Badwrench
Excuse me for making a mistake in the way I quoted the decimal. My bad. Run your valves to .007 then. I don't know a damn thing.</TD></TR></TABLE>
not meant to flame bro but there is a big frikin difference between 0.1 and 0.001
oh and here is the spec out of the book and you will see that 0.001 is well within the tollerances:
in the book it is actually :
0.006 - 0.007 intake
and
0.007 - 0.008 exhaust
so putting them both at 0.007 is fine
Old Sep 17, 2006 | 12:14 PM
Hybrid96EK's Avatar
and
so putting them both at 0.007 is fine</TD></TR></TABLE>
You're right.
Old Sep 17, 2006 | 12:15 PM
Mr. Badwrench
no harm meant bro.....have a good one
Old Sep 17, 2006 | 02:49 PM
SiKid86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">where do you see 0.10? .1 is a tenth. .001 is a thou and the leeway is more than that. if the spec is 0.006 and then a tenth would be 0.106
0.007 is fine. </TD></TR></TABLE> could mean one tenth of a thousandth... .0001... .1 is more known as one hundred thousands.. Geesh.
But I have yet to see a feeler gague go that small.
Suck my DX
May 26, 2005 09:25 PM
HatchbackSiVtec
16
May 12, 2005 05:59 PM
SPOON_FED_DC_2
Apr 4, 2005 09:33 PM
hitvtecgetloud09
31
Mar 14, 2005 09:50 AM
brixity
Feb 7, 2005 03:13 AM
