B16 Cams
Re: (CRXified)
You should be fine if you don't go over the stock revlimit.....
But I would upgrade them to tap into the power above that (i think they produce power up to about 8500-8700)
Also....I don't know if the valve spring/retainer life is reduced because of the increased lift
Re: (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ »</TD></TR><TR><TD CLASS="quote">You should be fine if you don't go over the stock revlimit.....
Also....I don't know if the valve spring/retainer life is reduced because of the increased lift</TD></TR></TABLE>
He'll never get to 8700 RPM with a stock ECU.
Re: (hondapwr)
what ecu program would you suggest then? supposed to pick up some 00 ITR cams this weekend and I still don't know what I'm gonna do about the ecu. local tuners say to dyno-tune and run uberdata or crome, but that is because they get to charge me the dyno fees. i just would like a program that would work better with the cams than my stock P30.
Re: (93ejay1)
first to fail in the bottom end is supposedly the rod bolts. can't remember when, but the occasional 9k redline should be OK, but not everyday.
Multi-paradigm
Re: (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote"> i know the head can if u get springs and retainers but can the blocks internals rev that high?</TD></TR></TABLE>
easily.
but it's not necessary to rev even a stock ITR motor, let alone a b16, to 9000 grand. they don't make power up there and it just causes useless wear on you internals.
easily.
hitvtecgetloud09
31
03-14-2005 09:50 AM
