Valve float on H22?
Old Mar 19, 2005 | 11:31 PM
Pikachu's Avatar
Default Valve float on H22?
Currently I'm building my bottom end pretty much bulletproof. I however haven't done a single thing to the head. I'm not going to be revving past the 7500 redline h22's have. So am I safe running this? I'm trying to run 400-450whp on my car. I will build the head in the near future when the funds become available but at the time being, can I run a stock head without the possibility of having a valve float on my h22?
I really rather spend my current funds for the rest of my turbo setup. Please help guys.
Old Mar 20, 2005 | 12:39 AM
Tyler H's Avatar
Default Re: Valve float on H22? (Pikachu)
Not that I'd recommend it, but I've taken a completely stock head as high as 8400 rpm. I took it to 8000 rpm pretty regularly. This was on ~25psi. It wet a bunch of 10.50-10.60's in the low-130's mph on the stock head.
Tyler
Old Mar 20, 2005 | 03:58 AM
speedworks's Avatar
Default Re: Valve float on H22? (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">Not that I'd recommend it, but I've taken a completely stock head as high as 8400 rpm. I took it to 8000 rpm pretty regularly. This was on ~25psi. It wet a bunch of 10.50-10.60's in the low-130's mph on the stock head.
Tyler</TD></TR></TABLE>
same here with no problems, it will be fine
Old Mar 20, 2005 | 06:36 AM
h22 civic's Avatar
Default Re: Valve float on H22? (speedworks)
i got a set of brand new supertech valves for the h22 they are nitride coated and dished for turbo and are standard size i got them from earl make ofer
projectef
Apr 25, 2007 06:44 PM
DMF
Oct 10, 2005 09:54 AM
FastAllmotorLsVtec
May 1, 2004 08:20 AM
2000Accord5sp
Sep 10, 2002 01:31 PM
