Valve cover venting ????
Old Oct 16, 2006 | 03:50 PM
  #26
IT'S ME DAVID's Avatar
NooB
Default Re: (1Quikgsr)
thats nice.
Old Oct 16, 2006 | 04:25 PM
  #27
Tchleung's Avatar
Here's mines. Endyne breather setup and 8an lines off valve cover
Old Oct 16, 2006 | 04:28 PM
  #28
siblues's Avatar
Default Re: (Tchleung)
Looks good man and that topmount looks great
Old Oct 16, 2006 | 04:41 PM
  #29
shortyz21's Avatar
Default Re: (siblues)
i ask again why the stock vent isnt good enough?
someone who has these lines explain what they do instead of just saying "PCV". i dont understand why there is 2 huge *** lines.
Old Oct 16, 2006 | 04:55 PM
  #30
siblues's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">i ask again why the stock vent isnt good enough?
someone who has these lines explain what they do instead of just saying "PCV". i dont understand why there is 2 huge *** lines.</TD></TR></TABLE>
In here is everything you need
https://honda-tech.com/zerothread?id=1199935
Old Oct 17, 2006 | 01:48 PM
  #31
Tony the Tiger's Avatar
Default Re: (Laserjock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock &raquo;</TD></TR><TR><TD CLASS="quote">^ stealth! Lines go to the black box where the old battery location was?</TD></TR></TABLE>
Actually, the black box is a reservoir for the water injection... I am running an exhaust PCV evacuation setup, so those two tubes are connected to the exhaust
Old Oct 17, 2006 | 03:17 PM
  #32
dannydos's Avatar
Default Re: (Tony the Tiger)
nice pics
Old Oct 17, 2006 | 03:24 PM
  #33
riceball777's Avatar
Default Re: (IT'S ME DAVID)
heres mine
i only run 1 -12 in front of the valve cover but i will add another one soon
Old Oct 18, 2006 | 12:36 PM
  #34
G
sh!t happens.
Default Re: (riceball777)
Are you guys running catch cans on the back of the block? or just the valve cover?
Old Oct 18, 2006 | 12:41 PM
  #35
mike1114's Avatar
Default Re: (G"UNIT)
A lot of us run vents on the back of the block (endyn style) and the valvecover.
Old Oct 18, 2006 | 01:39 PM
  #36
sp00led's Avatar
Tchleung, how did you get your valve cover tapped without messing it up when welding the fittings in. I want to tap my red honda itr cover but I don't see any way to do it without scraping off paint or burning the area around the welds.
I'm still not sold on the fittings posted on page 1, worried they might leak.
Old Oct 18, 2006 | 04:05 PM
  #37
1Quikgsr's Avatar
Default Re: (sp00led)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">Tchleung, how did you get your valve cover tapped without messing it up when welding the fittings in. I want to tap my red honda itr cover but I don't see any way to do it without scraping off paint or burning the area around the welds.
I'm still not sold on the fittings posted on page 1, worried they might leak.</TD></TR></TABLE>
i know i burned my red itr valve cover so i had it powder coated, chances are he did the same thing
Old Oct 18, 2006 | 04:15 PM
  #38
b18c4door's Avatar
OK, can someone explain something to me:
The endyn/moroso can has 2 fiitings: So, one removes the PVC box at the bottom and seals it up, adds 2 ports as mentioned and runs lines to catch can. A breather is added up top So, that pretty makes sense.
How do people run 2 line from front as well as 2 lines from below to the endyn/moroso catch can? Do you tee both lines to form 1?
Old Oct 18, 2006 | 04:30 PM
  #39
Tchleung's Avatar
Yeah I just stripped the valve cover beforehand, then drilled and welded the fittings on then got it recoated. Made sure to coat the welds as well so it looked 100% stock
Old Oct 18, 2006 | 06:53 PM
  #40
Default Re: (b18c4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4door &raquo;</TD></TR><TR><TD CLASS="quote">OK, can someone explain something to me:
How do people run 2 line from front as well as 2 lines from below to the endyn/moroso catch can? Do you tee both lines to form 1?</TD></TR></TABLE>
idealy you run 2 moroso catch cans. 1 can for the 2 fitting on the back of the block and 1 catch for venting the valve cover
Old Oct 18, 2006 | 09:25 PM
  #41
bigbadboy's Avatar
so is it really neccessary to run a separate catch can for just the valve cover??
Old Oct 18, 2006 | 09:40 PM
  #42
Tchleung's Avatar
Default Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">so is it really neccessary to run a separate catch can for just the valve cover??</TD></TR></TABLE>
The three lines coming off my valve cover are just free venting under the engine. Although next year I plan to route them into my exhaust.
Old Oct 18, 2006 | 09:50 PM
  #43
BodyKits NW's Avatar
What the largest AN fittings u can use with the Endyn kit. What threads in there anyways?
I guess a better question would be, what size line fit's over the nipples on the back of the block if going with stainless lines.
Old Oct 19, 2006 | 04:38 AM
  #44
mike1114's Avatar
Default Re: (BodyKits NW)
bodykitsnw........Z10 sells fittings for the back of the block that are push-on hose or Male AN threaded, I got the threaded ones, they use -12an.
Old Oct 19, 2006 | 04:58 AM
  #45
crex23's Avatar
How do you know if you need to run one catchcan or two, is it better to run the one off the back of the block or will one off the valve cover be okay? I'm turboed and hoping for around 350 hp when I dyno again. What do you all recommend?
Also, I know obviously if you run a catchcan off the back of the block, you get rid of the stock PCV system. But do you get rid of it if you only run off the valve cover?
Old Oct 19, 2006 | 05:06 AM
  #46
b18c4door's Avatar
Default Re: (crex23)
In Theory - I wonder if I could run 2 lines from the block and the line from the back of the valve cover (where a breather flter would go) into the catch can? I could get the endyn can and add another 3/8" NPT fitting and call it a day.
I would think that this would be sufficient for 400 whp. I think overall compression (and more boost) would warrant the need for extreme crankcase ventilation.
The braided lines from the valve cover add some serious bling, though!
Old Oct 19, 2006 | 05:07 AM
  #47
b18c4door's Avatar
The threaded fittings that screw into the back of the block - Anyone know the thread pitch is? I wonder if you could just use AN lines and run stainless lines to the endyn can? I am not a fan of the pop machine hoses, personally.
Old Oct 19, 2006 | 05:43 AM
  #48
mike1114's Avatar
between 300-400whp here...depending on gear......
I needed two catch cans. The one off the back of the block would fill up after a couple hard pulls. I added the second catch can and now the one from the back of the block doesn't fill up as much.
It has to do with the velocity of the air coming out of the catch can lines. More hoses/vents makes the velocity lower in each line so it will have less chance of picking up oil as it exists the motor. Also, some have a problem with when the oil sloshes to the back of the pan, it travels up the oil galleys and out the fittings on the back of the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4door &raquo;</TD></TR><TR><TD CLASS="quote">The threaded fittings that screw into the back of the block - Anyone know the thread pitch is? I wonder if you could just use AN lines and run stainless lines to the endyn can? I am not a fan of the pop machine hoses, personally.</TD></TR></TABLE>
Its -12 an like I said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4door &raquo;</TD></TR><TR><TD CLASS="quote">In Theory - I wonder if I could run 2 lines from the block and the line from the back of the valve cover (where a breather flter would go) into the catch can? I could get the endyn can and add another 3/8" NPT fitting and call it a day.
most likely will not vent enough but each motor is differnt so try it!!
Old Oct 19, 2006 | 05:51 AM
  #49
b18c4door's Avatar
Wow - 2 runs and it fills up! Thats a lot of oil! The moroso can is 11.3" x 4" which makes that for a lot of oil.
Thanks for correcting me, Mike. What you say makes a lot of sense. I appreciate it.
Old Oct 19, 2006 | 06:56 AM
  #50
What size fitting do I need to thread into the Endyn catchcan. What size thread or AN fitting is needed?
