valve adjustment specs for built engine?
Old Oct 9, 2005 | 07:43 AM
turbotime's Avatar
Default valve adjustment specs for built engine?
Hey im about to do a valve lash adjustment. I did some searching and it seems like i should just adjust to stock spec but i figured id ask. The valvetrain is somewhat built (retainers and springs) but the cams are still stock i believe. CR is at 8.5:1, 93 GSR engine.
So what should i aim for? Stock? If so where in the spectrum would be best for intake and exhuast?
thanks
Old Oct 9, 2005 | 08:19 AM
NJIN BUILDR's Avatar
Default Re: valve adjustment specs for built engine? (turbotime)
Lash spec.s are determined by the cam manufacturer,in your case oem.Just use the stock spec. and you will be fine.
Glenn
Old Oct 9, 2005 | 08:50 AM
vaporboy12's Avatar
Default Re: valve adjustment specs for built engine? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Lash spec.s are determined by the cam manufacturer,in your case oem.Just use the stock spec. and you will be fine.
Glenn</TD></TR></TABLE>
he is correct
#Leo#
Apr 4, 2009 07:07 AM
all-mtr-teg
Jan 6, 2007 09:57 PM
ultimatehonda
24
Sep 19, 2005 10:27 AM
AK94GSR
May 18, 2005 07:23 PM
Hatch_Back_97
Jun 2, 2002 05:48 AM
