VAFC Problems....Need Help
Old Oct 13, 2002 | 10:17 AM
CrX1988Zc's Avatar
Default VAFC Problems....Need Help
ok, well i have just finished installing the VAFC and dsm 450's in my car. have settings at -35. idles fine, runs ok until i hit about 30% throttle and the car falls on its face, bogs horribly. what could be the problem? everything is hooked up right, i've tried different settings on the VAFC. nothing seems to work. please help.....
Old Oct 13, 2002 | 10:51 AM
.ShawnD.'s Avatar
Default Re: VAFC Problems....Need Help (CrX1988Zc)
take it to the dyno .. i installed my before i had it dynoed .. ran like chit .. after dyno- awesome .. i was to rich
Old Oct 13, 2002 | 11:05 AM
CrX1988Zc's Avatar
Default Re: VAFC Problems....Need Help (.:s h a w n D:.)
hmm if i only had the money.......
Old Oct 13, 2002 | 01:28 PM
CrX1988Zc's Avatar
hmm its only doing it in the vacuum to boost transition if i go full throttle. if i ease into boost at like 20% throttle then go WOT it runs great. hmm what could it be...
Old Oct 13, 2002 | 03:04 PM
98civicEX's Avatar
are your nar. and wide throttle settins EXACTLY the same?
Old Oct 14, 2002 | 02:03 PM
CrX1988Zc's Avatar
Default Re: VAFC Problems....Need Help (98civicEX)
yea the settings are exactly the same. i tried -50 and it cleared up alot but its still way too rich it bogs when i first go WOT. im also now getting a map sensor code and an 02 sensor code. maybe it has something to do with the setings??
Old Oct 14, 2002 | 02:05 PM
rjardy's Avatar
have you tried it at -40%?
Rob
Old Oct 14, 2002 | 02:27 PM
mos's Avatar
mos
Default Re: VAFC Problems....Need Help (rjardy)
Got it worked out yet?
Old Oct 14, 2002 | 02:31 PM
CrX1988Zc's Avatar
Default Re: VAFC Problems....Need Help (mos)
yea, and as usual im a dumbass. i didnt have the settings right at all forgot about adjusting it for different rpms so i only had it adjusted for like 1000 rpm, so when it went over that it ran like ****.
fixed it now its set to -35 all the way acrossed pulls like a **** and dont lean out at about 8psi. i'll turn up the boost later.
thanks for the help anyways.
sir2sol
Apr 16, 2006 05:46 PM
smkngsr
Apr 11, 2005 05:58 AM
Art Vandeleigh
Oct 26, 2002 09:14 PM
Asahi
Jun 1, 2002 04:52 PM
