Vafc Hack in tank or FMU with Inline?
Old Jan 26, 2003 | 12:09 PM
88crxvtec's Avatar
Default Vafc Hack in tank or FMU with Inline?
I am begining my turbo project and will end up with a walbro 255 intank pump and an airteck inline fuel pump. I will also have a Vortec FMU and I already have a v-afc installed in my car. So my question is this. I am putting the turbo on my CRX with a b16 so should I buy injectors and do the hack or go with the FMU? Any input will be great. Thanks in advance!
Old Jan 26, 2003 | 12:48 PM
Daniel's Avatar
Default Re: Vafc Hack in tank or FMU with Inline? (88crxvtec)
Old Jan 26, 2003 | 04:04 PM
Joseph Davis's Avatar
Default Re: Vafc Hack in tank or FMU with Inline? (Daniel)
Anyone wondering FMU/AFC doesn't have the money for standalone + therefore is likely boosting a stock engine... so... go with one fuel pump or the other, both is overkill and pointless.
just to give you an idea: I've ran my stock HF pump at 9 psi with 450cc/AFC hack + chip to retard my ignition. The pump died after the car sat for two months, and I'm running 4-7 psi on a stock LS pump with no problems so far.
Depending on the efficiency/flow of your turbo, you may find your stock fuel pump dying at lower levels than I run, as I run a tiny crap turbo.
I advocate the AFC hack, with chipped ECU to overcome the increased ignition advance the AFC hack + OEM ECU gives you. There is no place for an FMU on a turbo Honda as the current technology stands.
batboy1720
Nov 15, 2004 07:05 AM
boostincoupe
Apr 10, 2003 12:48 PM
Andrew 825SM
Oct 29, 2002 07:35 PM
deacs
Sep 8, 2002 11:01 AM
KevronsEG
Aug 5, 2002 08:29 PM
