vafc hack 00 gsr?????
Old Nov 6, 2002 | 03:25 PM
Sachmo's Avatar
Default vafc hack 00 gsr?????
what resistors do i use , i got the 10 watt 10 ohm resistors wired in , and as soon as i go full throttle the car falls on its face, any suggetions??
tia
jonathan
Old Nov 6, 2002 | 03:35 PM
Sachmo's Avatar
Default Re: vafc hack 00 gsr????? (Sachmo)
ttt
Old Nov 6, 2002 | 04:19 PM
Sachmo's Avatar
ttt
Old Nov 6, 2002 | 04:43 PM
filetofit
Guest
Posts: n/a
How much of a cut are you running and at what RPMs?
Old Nov 6, 2002 | 04:58 PM
Sachmo's Avatar
Default Re: vafc hack 00 gsr????? (filetofit)
what do you mean by cut??
ive noticed something else to , my car will idle perfecrtley fine without pulling any fuel out ..why is that???
jonathan
Old Nov 6, 2002 | 05:23 PM
filetofit
Guest
Posts: n/a
By cut I mean what percentage reduction in fuel are you running and at what RPM? I assume you are using DSM 450cc injectors.
At idle you are going to be in closed loop so your o2 sensor and ECU are compensating for the larger injectors although I would venture you are running pretty rich at idle. Also larger injectors take longer to open so you don;t get as much fuel out of them as you would think for short pulsewidths.
Old Nov 6, 2002 | 05:25 PM
Sachmo's Avatar
o k i gotcha, im runnin - 36 across the board, and as soon as i go full throttle my a/f gauge goes completely red and its start to stumble
thanks
jonathan
Old Nov 6, 2002 | 05:32 PM
filetofit
Guest
Posts: n/a
They are DSM 450cc injectors correct? Because if you ran a high impedance injector with resistors they might not open all the way.
Red means lean on your A/F right? Try adding a little more fuel, the response of a narrow band A/F gauge isn't linear though so you just want enough to tip you over towards rich and it will occur pretty suddenly.
Also have you messed with the TPS sensor at all with your VAFC?
Old Nov 6, 2002 | 07:24 PM
DD_JonnyLee's Avatar
hey whats up , i was using my friends username earlier, yes they are dsm 450's, no i havent messed with the tps sensor with the vafc
tia
jonathan
[Modified by JonathanH, 4:26 AM 11/7/2002]
Old Nov 6, 2002 | 08:24 PM
filetofit
Guest
Posts: n/a
Default Re: vafc hack 00 gsr????? (JonathanH)
Beats me then. I take back what I said earlier, -35% should be plenty of fuel, Maybe a dirty/clogged injector, low fuel pressure, overboosting.
Old Nov 6, 2002 | 11:17 PM
Trac226's Avatar
Get a wideband sensor to read ure a/f ratios.
Old Nov 7, 2002 | 09:26 AM
B20T's Avatar
if u are using hi imp injectors you dont need the resistor
Old Nov 15, 2002 | 08:42 PM
Sachmo's Avatar
Default Re: vafc hack 00 gsr????? (B20T)
how do i know if i am using high impendence injectors, ???
i pulled themn out the other day , now im gonna attemp to put them back in ,thanks for any help
jonathan
Old Nov 15, 2002 | 09:17 PM
Sachmo's Avatar
ttt
forcefanajd
Mar 21, 2005 09:28 AM
0 0 0
Jan 24, 2004 05:15 PM
racinskittle
Jan 18, 2004 07:06 PM
DragInteg
Apr 3, 2003 11:49 AM
blazin
Feb 12, 2002 10:40 AM
