Vafc cel code "3" ... Need help
Old Sep 6, 2004 | 10:28 PM
labatt50's Avatar
Default Vafc cel code "3" ... Need help
Hi, i have installed a vafc in my stock civic si 93 hatch ( d16z6, p28 ecu)
It worked fine ran it for a month with no cel.
Last week i installed some second gen dsm 450cc because i am going to turbo the mad "D"
As recommend, i used new seal... i bored them out, i used 10watts 10ohms resistor... My engine i still stock so i set injector to shoot 46% less fuel because 450cc will dump too much fuel. 450cc -46% = ~240cc 239.2....exactly like oem injector.
Anyway... i started the car and it idle fine, run fine when i go for a test drive...
But i while i was on the higway my cel light up... CEL 3... map sensor!
The cel light up when i release throttle on 3rd 4th or 5th gear, if i release throttle and put the stick on neutral cel wont come, WTF!!! I did remove the fuse for the ecu so it should have reset...
i heard a lot of people had this problem... anyone can help?
Old Sep 7, 2004 | 01:43 AM
quik sol's Avatar
I got this exact same code....I sautered all my connections....code went away.
Your wiring must not be giving off a good enough current.
Old Sep 7, 2004 | 08:35 AM
labatt50's Avatar
Default Re: (quik sol)
i did solder all of my connection but i'll take a look again
Old Sep 7, 2004 | 08:38 AM
boosted_dc2's Avatar
Default Re: (labatt50)
set the sensor to 6 in and 6 out.
Landon
Old Sep 7, 2004 | 08:43 AM
labatt50's Avatar
Default Re: (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">set the sensor to 6 in and 6 out.
Landon</TD></TR></TABLE>
Thanks for your help, but it was already set at 6 in 6 out. There was no code with my stock injectors and now there is one with dsm injectors...
Old Sep 8, 2004 | 07:41 AM
well injectors have nothing to do with the map sensor, you might have the map input and output wires switched.
Landon
Old Sep 8, 2004 | 07:51 AM
USDM 4G VTEC's Avatar
when i had my SFC-VTEC on my N/A car i only got the code when i went over into + % on the settings since it was too much, the ecu took *****...
i guess u are too low.. try -40% all across
Old Sep 8, 2004 | 05:54 PM
labatt50's Avatar
Default Re: (USDM 4G VTEC)
i will try to richen a little bit more
Old Sep 8, 2004 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatt50 &raquo;</TD></TR><TR><TD CLASS="quote">i will try to richen a little bit more</TD></TR></TABLE>
thats not youre problem. when does the light come on??? is it only when you boost???
Landon
Old Sep 9, 2004 | 09:09 AM
djwest24's Avatar
Default Re: (rota92)
i dont think he's boosting yet (from his first post)
the exact same problem happened to me, no code even whn im boosting, but a second or two after i take my foot of the accelerator, it throws code 3.
it turned out tht my sensor in and out settings were wrong...now dont think im dumb...i set it right whn i installed and it was running fine for a couple of months.
im guessing ur setings, wiring or maybe ur map sensor's busted.
Old Sep 11, 2004 | 01:39 AM
labatt50's Avatar
Default Re: (quicksilver17981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver17981 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think he's boosting yet (from his first post)
im guessing ur setings, wiring or maybe ur map sensor's busted.</TD></TR></TABLE>
omg... i feel so stupid... my setting were all wrong! must be when i removed the battery... damn it! Now its working thank you guys!
92eg6
Feb 27, 2005 02:35 PM
Dyzee
Jun 15, 2004 04:28 PM
TurboBumblBee
Nov 8, 2003 10:44 AM
B00ST2nR
Apr 18, 2003 03:35 PM
