VACUUM LINES
Old Oct 1, 2001 | 08:07 AM
whagkangmakulet's Avatar
Default VACUUM LINES
ok guys! I have a 90 Civic hatch w/ a custom T3 turbo. I've been running my hatch for about 1 month now and I decided to increase my boost at least by 8lbs. I bought a manual boost regulator and i attach another T's along with the FMU. I felt the big difference as far as power ..but i notice that I don't hear my wastegate opening and when i reach 8lbs..I'm leaning out big time!! It feels like it's going to blow! where do you guys hook up your vacuum lines for the wastegate? here is my setup..
T3 TURBO
TIAL 35MM WASTEGATE
VORTECH FMU 10:1
MSD FUEL PUMP 255LPH INLINE
RC ENGINEERING 310CC INJECTORS
BLITZ DD BLOW-OFF VALVE
3- ONE WAY VALVE(MAP SENSOR)
CUSTOM DOWNPIPE 2-1/4" W/ 2" EXHAUST SYSTEM
STARION INTERCOOLER
CUSTOM 2" PIPING
Old Oct 1, 2001 | 08:24 AM
92CivicSiR's Avatar
New User
Default Re: VACUUM LINES (whagkangmakulet)
To the top hole on the Tial.
Old Oct 1, 2001 | 09:27 AM
Default Re: VACUUM LINES (92CivicSiR)
WHAT ABOUT THE TOP HOLE OF THE TIAL? i ORIGINALLY HAVETHE BOTTOM PART MY TIAL CONNECTED DIRECTLY ON THE TURBO. WHAT'S THE TOP ONE FOR?
Old Oct 1, 2001 | 11:37 AM
TurboInteg95's Avatar
the top port is for an electronic boost controller that pulses the top side of the diaphram to increase and regulate boost and boost response.
Old Oct 1, 2001 | 01:22 PM
Default Re: VACUUM LINES (TurboInteg95)
THANKS..HOW ABOUT MY PROBLEM? CAN YOU PUT THE FMU AND THE WASTEGATE ON THE SAME VACUUM LINE? ANY PICTURES OF THEIR SETUP?
Old Oct 1, 2001 | 01:31 PM
wastegate does not need a vac line. Just run it off your boost piping.
h22a_junkie
Apr 24, 2007 05:08 PM
DIRep972
Sep 11, 2004 01:26 PM
OnPointDX
Oct 25, 2003 09:03 AM
