Vacuum line placement?
Old Sep 3, 2009 | 12:07 PM
95sloweg's Avatar
Default Vacuum line placement?
Here is my set up it a stock d16z6 with a t3 garret turbocharger, tial wastegate, and greddy type s BOV. i want to know the best places to t my lines to pull vacuum. any insight will be great.
My wastgate line is going to the turbo. My boost gauge i think ill t into the brake booster line, but do i do it on the motor side of the check valve or the master cylinder side of the check valve? my Bov i guess i can t into the purge solenoid valve line that goes to the canister, is that a good line to t into?
This is my first turbo set up so i want to double check before i start cutting up hoses. Please keep the rude remarks to yourselves. Thanks in advance.
Old Sep 3, 2009 | 12:18 PM
AR_96's Avatar
Default Re: Vacuum line placement?
i need to know the same thing lol
Old Sep 3, 2009 | 12:38 PM
kyden's Avatar
motor side of the check valve.
Old Sep 3, 2009 | 12:41 PM
Rickcrx's Avatar
Get a vaccum manifold.Thats the best way!!!!!
Old Sep 3, 2009 | 03:28 PM
oodie's Avatar
X2 vendor Fast-Turbo has them on here. Cleans up bay so much better and work.
Old Sep 3, 2009 | 05:03 PM
roadsqueegy95's Avatar
ya i got a golden eagle vac mani. cleans everything up, and easy to find a place to pull vacuum then
Old Sep 3, 2009 | 09:56 PM
95sloweg's Avatar
just picked up a Full-Race vac mani. I guess ill just tap into the brake booster line and run the vac lines to that.
Old Sep 4, 2009 | 02:00 PM
95sloweg's Avatar
i ran the boost gauge and the top line on the BOV to the vac mani, but i am not sure what to do whith the bottom fitting on the BOV. I read that some t it somewhere and some leave it open. Which is better?
South Bay Surfer
Jul 5, 2008 06:34 PM
afterburners
Jun 10, 2004 08:44 PM
wickedxboi
Feb 28, 2003 09:07 AM
b18bvudoo
Jun 29, 2002 11:08 PM
