vacuum? how to get a higher pressure?
Old Apr 4, 2006 | 08:41 PM
the.hamburglar's Avatar
Default vacuum? how to get a higher pressure?
im getting about 19in/hg right now. i read that is on the low end of the pressure that should be created at idle? so either i have a small leak somwhere or something else can be adjusted? what can i do?
Old Apr 4, 2006 | 08:47 PM
mtber's Avatar
Default Re: vacuum? how to get a higher pressure? (the.hamburglar)
..... leak down & compression test.
Old Apr 4, 2006 | 09:05 PM
Default Re: vacuum? how to get a higher pressure? (mtber)
compressoion is fine, i just rebuilt the motor. what should the vacuum read
Old Apr 4, 2006 | 09:22 PM
black98gsr-t's Avatar
mines at 20-21in hg. on stock motor... 19 isn't that big a deal , how long since the rebuild? ring end gaps ? timing?
Old Apr 4, 2006 | 09:43 PM
Default Re: vacuum? how to get a higher pressure? (black98gsr-t)
not even 60 miles. like 2 weeks ago i put it in
Old Apr 5, 2006 | 11:46 AM
id put a few more miles on it before i do anything.. if your ring end gaps were to big that could have an effect but get it tuned and just drive it for awhile.. just my 2cts.
Old Apr 5, 2006 | 11:48 AM
mike1114's Avatar
As you drive it the rings should seat more making the vacuum go up some.
As others said. Don't worry, put more miles on the car and keep an eye on it.
Old Apr 5, 2006 | 01:43 PM
Default Re: vacuum? how to get a higher pressure? (mike1114)
its running rich at idle right now. about 13:1. ill tune it soon once i get a laptop. in the mean time it will stay parked
Old Apr 5, 2006 | 02:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
break it in, and make sure the timming is set right. you should be ok.
protopro88
Apr 12, 2011 10:59 PM
150plusZ
Jan 31, 2009 08:38 AM
hondaeg8
10
Jun 21, 2005 11:17 PM
dunkd
Mar 29, 2004 07:12 PM
HX_Guy
Dec 7, 2001 04:28 PM
