Vacuum hose question
Old May 13, 2002 | 10:49 PM
shadowdawn's Avatar
Default Vacuum hose question
My vacuum hoses now (stock ones) are 5mm... would using 4mm be just as good or even better for BOV, wg, FMU? (They are all off the fpr). I'm not looking for a performance gain here, but if in the process to make my appearence better I could get a better suited mm rating hose I'll get that...
Main question, is bigger diameter or smaller diameter better for vacuum hoses for BOV, FMU, WG?
Old May 14, 2002 | 03:19 AM
MiraiZ's Avatar
Default Re: Vacuum hose question (shadowdawn)
as long as the walls are thick enough to handle the pressure, you should be ok...sometimes higher pressue can cause the walls to cave in and pinch the air flow...so be careful
Old Sep 1, 2002 | 12:46 PM
accordfreak's Avatar
Default Re: Vacuum hose question (MiraiZ)
what is the recommended size vac hoses??? would using a smaller diameter vac hose for the tial wastegate lower the boost levels? i'm not getting much boost with the tial wastegate after i took out the delta because the fitting on the deta has a smaller diameter fitting hole for the hose. and the hose from the deta doesn't seem to fit the tial.
btw: stock hoses are 5mm?
[Modified by accordfreak, 9:47 PM 9/1/2002]
Old Sep 1, 2002 | 01:22 PM
b18bvudoo's Avatar
New User
Default Re: Vacuum hose question (accordfreak)
my hoses are 4mm except for the wg hoses, which are 6mm
rocket256
Mar 13, 2005 03:38 PM
Mario.
Oct 5, 2004 03:12 PM
gdrum
Feb 16, 2004 10:21 PM
teal EJ1
Aug 24, 2003 09:19 AM
LEON
Aug 10, 2001 05:13 PM
