Vacuum help
Old Aug 13, 2004 | 03:51 PM
MooreBoost's Avatar
Default Vacuum help
I am currently using the nipple on the elbow of my 14b turbocharger as the vacuum source for my wastegate. I just read that that can cause the turbo to spool slow, which I am having trouble with. They said its better to tap at the intake manifold for the vacuum. But that will cause me to run more PSI right?
However they also said that tapping a source for the wastegate can cause erratic boost, and that its better to give it its own source, but how will I do that?
Old Aug 13, 2004 | 03:55 PM
MooreBoost's Avatar
Default Re: Vacuum help (tegunderpressure)
Did alittle search, one guy ditched the charcoal canister and used the vacuum source for that. Can I remove that without throwing a CEL?
Edit- looks like I can. Ill give that a shot.
Old Aug 13, 2004 | 05:54 PM
Cramerox's Avatar
yes you will run just a bit more boost if you take a source after the IC ex. like the intake manifold. since you are taking a presure source after the IC, it will compensate for any pressure drop after the IC.
You can tap straight from the brake booster.
If you are doing this to get quicker spool time i dont think it will make a difference where you tap it. You will get better results running a boost controller. Running boost controller doesnt mean you have to up the boost.
jetspeedz
Aug 23, 2009 02:21 PM
goldex420
Apr 3, 2008 05:10 PM
chriskey0829
Feb 1, 2006 07:10 PM
1boostedcivic
Sep 1, 2005 06:05 PM
airwalk07143
Nov 6, 2004 05:13 PM
