Vacuum/boost problems with turbo EG
Old Aug 20, 2006 | 07:29 PM
asiandeity's Avatar
Default Vacuum/boost problems with turbo EG
I just installed a Peakboost turbo kit in my civic hatch with a fully built b18C. I got the vacuum lines from the bov, wastegate, and AEM 3.5 map sensor to a golden eagle vacuum block. My boost gauge is t'd into the fuel pressure regulator. When I start the car, it shows 15 in Hg of vacuum and when I step on the gas, it only goes up to 10 in Hg on the vacuum side. I'm using the AEM EMS for engine management. The whole valvetrain is Skunk2. Can cam timing effect vacuum/boost? Any help would be appreciated.
Old Aug 20, 2006 | 08:22 PM
OBRJosh's Avatar
Default Re: Vacuum/boost problems with turbo EG (asiandeity)
I would say it should be higher then 15 mines at 22 at 800rpm, well according to the autometer boost gauge
Old Aug 20, 2006 | 08:26 PM
OBRJosh's Avatar
Default Re: Vacuum/boost problems with turbo EG (OBRJosh)
When you hit the gas it should go to 0 by the way
Old Aug 20, 2006 | 08:41 PM
asiandeity's Avatar
It's not going that far. Are you having any luck with your problem?
Old Aug 20, 2006 | 08:45 PM
OBRJosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asiandeity &raquo;</TD></TR><TR><TD CLASS="quote">It's not going that far. Are you having any luck with your problem?</TD></TR></TABLE> Me? I have zero problems, i was helping you out haha, Higher the Vacum the better, not lower, mine was at 15 before i did a valve adjustment and i had really low compression my valve werent closeing all the way, adjusted the valves gained Alot of compression and more vacumm..
Old Aug 20, 2006 | 09:44 PM
asiandeity's Avatar
Thanks for the suggestion. When I had put the motor back together, I had problems keeping the car running. Come to find out, one of the cylinders's compression was too low and I had the valves adjusted. I'm not sure if the mechanic had adjusted all the valves or just the ones on that cylinder. Maybe I need to adjust them all again.
BenN.Y.
Aug 28, 2013 09:22 PM
grizzled
Jul 9, 2006 09:46 PM
95civ
Aug 19, 2005 06:05 AM
elpiar
Mar 21, 2005 09:09 PM
b20b
Feb 12, 2002 07:20 PM
