vacum lines
Old May 25, 2004 | 10:21 AM
RACEPAK's Avatar
Default vacum lines
what size of vacum lines/T-fittings/(boost controler) do i need??
should it be the same size of the wastegate tube (internal)? i have an IHI rhb5
this project:
https://honda-tech.com/zerothread?id=865031
best regards moshik galimidi
B18 CYA's Avatar
bump cuz i need to know too
Old May 25, 2004 | 10:40 AM
Egg-weezy's Avatar
Default Re: (c2nap)
yeah it should be the same size as the one on the wastegate. I think i'm using 7/32....not sure.
Old May 25, 2004 | 11:17 AM
RACEPAK's Avatar
Default Re: (MidoriHB)
i checked the wastegate tube with a caliber it says 3.87mm (inner diam.)
and 6.55 (outer diam.)
so what hose size do i need ?
and what about the T-fittings and the manual boost controler ?
best regards moshik ga..
Modified by RACEPAK at 8:38 PM 5/25/2004
Old May 25, 2004 | 12:42 PM
rtype11's Avatar
Default Re: (RACEPAK)
1/8 and 1/4 respectively will fit the fittings.
Old May 25, 2004 | 09:05 PM
RACEPAK's Avatar
Default Re: (rtype11)
bump
geezer_187
May 8, 2006 04:18 PM
97gsrki
Jan 21, 2006 09:22 PM
W O T
Feb 20, 2005 12:44 PM
deftones0817
Feb 2, 2005 07:13 AM
qwklude82
Dec 30, 2002 06:49 PM
