Vac Lines & Map Bypass help.
Old Dec 23, 2008 | 09:16 AM
zach1288's Avatar
Default Vac Lines & Map Bypass help.
I am currently installing a turbo on my D16y7. I have all the parts and know how to set everything up. The only problem is i don't know where the vac lines from my turbo and boost controller need to go? Does anyone have a diagram? Also i don't understand the map bypass or check valve stuff i have to setup can someone explain to me or show me some pictures?
Old Dec 23, 2008 | 07:12 PM
zach1288's Avatar
Default Re: Vac Lines & Map Bypass help.
bump
Old Dec 23, 2008 | 07:18 PM
fmfkid250's Avatar
Originally Posted by zach1288
bump
This is soon to be 2009, Give us some more Details about this Map "bypass"
To do this right you need to use your map and not bypass it.
Old Dec 23, 2008 | 07:42 PM
zach1288's Avatar
Never mind. I did more research and i don't need to do this. All i need to know is where and what vac lines i need to use. I bought a vacuum manifold im just not sure what vac lines i need to use etc.
Old Dec 24, 2008 | 02:48 AM
boostedcivicsir's Avatar
Mr. Badwrench
tee the manifold inline with the brake booster, little fittings go to, map, fp regulator, bov, wastegate if you arent usint the compressor for boost reference, boost gauge, and thats all i can think of now.
Old Dec 24, 2008 | 02:54 AM
Schister66's Avatar
Man U FTW
I dont know about the bypass, but here's how i ran my vacuum lines
Old Dec 24, 2008 | 03:02 AM
Mr. Badwrench
thanks adam i was trying my best to find the last thread you posted that pic in, but the search feature sucks so bad. ooops did i say that out loud?
Old Dec 24, 2008 | 04:52 AM
Schister66's Avatar
Man U FTW
I'm sure you would have found it with the old search system...Lord knows i've posted it enough times
Old Dec 24, 2008 | 06:23 AM
zach1288's Avatar
Thanks everyone.
sewokozak
Engine Management and Tuning
Aug 9, 2018 02:08 PM
fabmaster
Apr 12, 2010 04:44 PM
Fuzzy Rhubarb
Oct 11, 2007 01:01 PM
eightvalver
Aug 23, 2004 08:41 PM
