aebs sleeved block
Old Dec 23, 2008 | 07:27 AM
2fastek's Avatar
Default aebs sleeved block
im buying a aebs sleeved block and was wondering what are the signs of a sleeve sinking/sunked sleeve? i just want to make sure the block is not f'd up. thanks in advance!
Old Dec 23, 2008 | 11:40 AM
SD_Lurker's Avatar
HT White Ops
Default Re: aebs sleeved block
Put a straight edge on it and see if one sleeve happens to be lower.
Old Dec 23, 2008 | 12:02 PM
allmotorB18eg's Avatar
i would not wast my money on a aebs sleeved block i have been hearing a lot of problems with there sleeves lately and if you buy it used your taking a chance because they will not cover any warranty. lots of shady guys that will sell there blocks because they have a problem with it and figure better to sell it and burn the next guy then get burned them self bottom line if you buy it used its at your own risk
Old Dec 23, 2008 | 12:03 PM
SD_Lurker's Avatar
HT White Ops
You know I was gonna say something to that effect but I didn't want to get flamed.
Old Dec 23, 2008 | 12:50 PM
CerealKiller's Avatar
underlined lettering = personal opinion
Bold lettering = truth.
Old Dec 23, 2008 | 02:29 PM
2fastek's Avatar
where would i get an str8 edge from
Old Dec 23, 2008 | 03:22 PM
lol if you need to ask don't buy it your not qualified to use it. don't be cheep just buy ether a fresh sleeved block or send yours to get sleeved remember you get what you pay for
Old Dec 23, 2008 | 03:55 PM
SD_Lurker's Avatar
HT White Ops
Home depot or any tool/hardware store. Like stated above it appears that you lack mechanical skills so maybe it would be best if you just bought a new sleeved block.
Old Dec 23, 2008 | 08:14 PM
2fastek's Avatar
its not that i lack mechanical skills its just that i never had to check the deck on a block before so... yea anyways, i took the block to the machine shop and they said its fine. Thanks HT.
Old Dec 24, 2008 | 07:33 AM
so you took it to a machine shop and had them check the deck well thats all fine and good except all that tells you is that the deck is good it does not tell you if the block is leaking mixing coolant and oil. it does not tell you if all the little holes in the sleeve will match up with your gasket because a lot of there sleeves block coolant ports and if thats the case good luck with the hot spots and blowing gaskets. oh well at least you cant blame ht for bad advise because we all told you to stay away from it the only one you can blame is your self for buying a junk block.good luck with that
MR.johnson
Jul 18, 2012 06:44 PM
98_Milano_Teg
Jan 30, 2012 03:35 AM
dc2luver
Jul 15, 2009 08:44 PM
sydb16
Oct 29, 2007 08:07 AM
EFin' Kyle
Sep 26, 2005 07:18 AM
