v-afc & FMU
Old May 25, 2002 | 11:12 AM
Evil EG's Avatar
Default v-afc & FMU
If I am running the V-AFC do I need an FMU?
Old May 25, 2002 | 12:07 PM
shadowdawn's Avatar
Default Re: v-afc & FMU (BVM)
If you do the 440 or 450 injectors then no, otherwise yes.... you want bigger injectors anyway.
Basically if you get 440's or whatever ditch the FMU and set low and high throttle -30% give or take according to your needs.
Old May 25, 2002 | 12:14 PM
inspyral's Avatar
If you're running a limited MAP and try to add fuel with the V-AFC, you're going to throw a MAP sensor code if you try to add too much fuel since the V-AFC alters the MAP signal to make the ECU dump more fuel. Without an FMU, you'll need to add A LOT of fuel with the V-AFC under boost. I'm running a 12:1 FMU and using a V-AFC to trim fuel under boost, since the FMU makes it run a bit rich. No problems.
edit:this is assuming you're running stock injectors
[Modified by inspyral, 1:15 PM 5/25/2002]
Throwdown
Jun 22, 2006 05:55 PM
Tdawg1030
Jun 17, 2005 10:58 PM
Hyaboosta
Sep 21, 2004 10:06 AM
P_t0wn
16
Jul 11, 2003 08:41 PM
TurboTeG4
Jul 4, 2002 04:37 PM
