v-AFC 2 sensor check question?
Old May 3, 2004 | 05:24 PM
highboostb18c1's Avatar
Default v-AFC 2 sensor check question?
on the vafc 2 if you go to ~ etc.-->Sensor check--> thrt---> what arte you reading on volts? someone said i should be running around .5 -.56 volts to my tps sensor, anyone ever heard this befor or know this for sure? i'm reading .475 volts and i have a crappy idle. i think if this is true it might have something to do with this, any info is key.
its a 2000 integra gsr with a drag gen 3 turbo kit
vafc-2
RC 440cc's injectors
walbro 255, aem rail, msd cap/coil,
thanks
Old May 3, 2004 | 05:28 PM
rioninja's Avatar
Default Re: v-AFC 2 sensor check question? (highboostb18c1)
TPS voltage at close is supposed to be between .45 and .5, so thats not your problem...
Old May 5, 2004 | 06:01 PM
dunkd's Avatar
yah .5 at idle, .45 at WOT - maybe try checking it with a voltmeter right at the tps, the VAFC could be off - im guessing that isnt your problem though.
im going to have to say your fuel settings on the vafc are off...
should look something like this... if ur closer to -50 at 1-4k then it wont idle good.
1-4k= -40%
4.5k= -38%
5k= -36%
5.5-8k= -35%
if your fuel settings are off then it could make you throw a MAP code... stock map can handle up to 11psi.
Modified by dunkd at 7:26 PM 5/5/2004
evo
Apr 6, 2003 09:32 AM
lsvtec101
Apr 4, 2003 04:05 AM
NC-B17A
Feb 16, 2003 08:46 PM
GSRacer
Dec 12, 2001 04:19 PM
