using vafc for boost over gauge.>>
Old Jul 23, 2003 | 08:51 AM
platinum00's Avatar
Default using vafc for boost over gauge.>>
stock map sensor is good for like ~10.65 psi right. im trying to get as close to that as possable. say around 10.5 is fine.
problem is gauge reads like 11psi. vafc reads .65 which = ~9.243psi.
should i stick with what the gauge is saying or go for vafc reading of ~.738 which would be 10.5psi.
if the afc gets that reading from the map. i think i should go with the afc reading, prolly more correct.
any sugestions. ??
platinum.
Old Jul 23, 2003 | 10:14 AM
15psi of fun's Avatar
Default Re: using vafc for boost over gauge.>> (platinum00)
I would go with the Vafc over the gauge I had the same thing going on in my car the auto meter was saying 11psi and the Vafc was saying .62(8.99psi).
Old Jul 23, 2003 | 12:38 PM
platinum00's Avatar
Default Re: using vafc for boost over gauge.>> (jz)
thanks.
that's what i thought just making sure..
Old Jul 23, 2003 | 02:19 PM
Accord94DX's Avatar
My SAFC reads lower boost than what my omori 1.0 bar gauge reads. I trust the omori more considering it is directly connected to the intake plenum, no electronic bullshit.
Old Jul 23, 2003 | 02:21 PM
Accord94DX's Avatar
Default Re: using vafc for boost over gauge.>> (Accord94DX)
same #s too! Boost gauge says .4bar, SAFC says .28
Old Jul 23, 2003 | 02:33 PM
platinum00's Avatar
i understand that the gauge is prolly more accurate, but what im getting at is. im not going over the map limit untill the vafc reads .75 which would be just over 10.65 . so i can boost untill i hit that without worries of fuel cut off or not be compensated for.
correct.
Old Jul 23, 2003 | 02:35 PM
b18b98's Avatar
I have this same problem also. My boost gauge reads 10.5psi and my blitz turbo timer with peak boost reading .72 bar while my SAFC reads .45 bar(6.5psi). I trust my gauges more because my boost gauge is teed off the fpr vac line while my turbo timer is teed off of its own vac source (brake booster).
Old Jul 23, 2003 | 02:46 PM
platinum00's Avatar
Default Re: using vafc for boost over gauge.>> (b18b98)
that's a really big difference. are you running a stock map sensor.
Old Jul 23, 2003 | 02:55 PM
b18b98's Avatar
yes.
Old Jul 23, 2003 | 09:05 PM
Accord94DX's Avatar
seems like that safc/vafc reads lower boost for some reason
Old Jul 24, 2003 | 04:47 AM
platinum00's Avatar
electrical **** never seems to read right.
Old Jul 24, 2003 | 05:48 AM
Xscream's Avatar
Are you guys running this on a AFC hack or AFC/FMU setup?
I thought you had to run a missing link with a FMU setup but just wanted to double check.
Old Jul 24, 2003 | 08:03 AM
platinum00's Avatar
Default Re: using vafc for boost over gauge.>> (Xscream)
im running the afc hack with 450cc's
TurboTagTeam
Apr 25, 2005 07:28 PM
hotintegranights
Apr 26, 2004 04:45 PM
Cee_mon
Sep 18, 2003 01:57 PM
Slater
Apr 19, 2002 01:49 PM
schwett
Dec 8, 2001 01:42 PM
