using screen on your turbo...good or bad..?
Old Dec 16, 2001 | 08:56 PM
c-notecoupe's Avatar
Default using screen on your turbo...good or bad..?
i heard that you could use screen insted of the air filter on the turbo if so what kind of screen should i buy or should i not do this
-thanks
Old Dec 16, 2001 | 08:59 PM
JM Performance's Avatar
Default Re: using screen on your turbo...good or bad..? (92cxhatch)
And what stops dirt and dust from getting in???
[Modified by 00SilverLS, 12:59 AM 12/17/2001]
Old Dec 16, 2001 | 09:37 PM
DIRep972's Avatar
Smarter than you
a screen is better then nothing, a good filter is better then a screen. ive been running a screen now for 1700 miles but i would much rather be using a filter.. I havent yet had the oppurtunity to meet the majic filter that fits my turbo.
Old Dec 17, 2001 | 04:26 AM
Default Re: using screen on your turbo...good or bad..? (DIRep972)
ttt
Old Dec 17, 2001 | 04:35 AM
98Psi ITR's Avatar
Unfortunately I can't really run just a screen living in a damn desert.
Old Dec 17, 2001 | 08:44 AM
Blown90hatcH's Avatar
Default Re: using screen on your turbo...good or bad..? (98Psi ITR)
If you have the money, get the filter. IF you dont have the money, get the filter.
[Modified by Blown90hatcH, 9:44 AM 12/17/2001]
Old Dec 17, 2001 | 08:55 AM
Seraph0's Avatar
Don't use just a screen
Old Dec 17, 2001 | 10:05 AM
TurboSedan's Avatar
New User
Default Re: using screen on your turbo...good or bad..? (MarkC)
Screen is not safe, use the damn filter.
Old Dec 17, 2001 | 11:42 AM
Charles B.'s Avatar
Default Re: using screen on your turbo...good or bad..? (97CivicFerio)
Assuming its for daily driving, use a filter. With the money you spent on your turbo, you don't wanna **** it up cuz u were too cheap to get a filter.
Old Dec 17, 2001 | 12:09 PM
jinxproof99's Avatar
New User
-thanks
i've run both. the screen actually takes away some power. some supra guys i know did some dyno runs w/ or without. they said it interfered with the flow. they actaully made more power w/ a filter. i'd go with a filter......you can take it out at the track and go bare.
Old Dec 17, 2001 | 01:55 PM
InfamousRS's Avatar
Default Re: using screen on your turbo...good or bad..? (jinxproof99)
What is the better filter to use? What about that Metal mesh filter make by Blitz (I think)?
Old Dec 17, 2001 | 03:10 PM
dbman96's Avatar
New User
that actually makes sense; the filter disrupts the flow but over a larger area, and then the intake pipe allows time for the flow to smooth out again. A screen over the turbo inlet would make a very small-area turbulent entry to the turbo (and draw hot air from right next to the exhaust manifold) and I can definitely see it making marginally less power.
Old Jan 13, 2002 | 10:19 PM
elgietech's Avatar
In every application you should always use an air filter whenever possible. Unless you have a clearance problem, it will always be the safer bet. Some people may opt for the mesh screen as opposed to the air filter to maybe free up some restriction as well as a few ponies, but in the long run you subject the turbo to larger microns of dirt and rock particles smaller than what the naked eye can see but large enough to damage the internals such as the seals and the turbine wheel. These same particles can not only damage your turbo but your engine as well. I should mention that oil changes will be more frequent due to camtamination, which in turn will shorten the viscosity life of your oil, which like water, is the life support of your entire engine. So you have to ask yourself, is saving a $30-100 on filter system worth losing few thousand dollars on rebuilding your engine?
Old Jan 14, 2002 | 04:06 AM
PLAYA HATIN HATA's Avatar
This may sound weird, but Ive heard using womens pantyhose works better than screens if you cant find a filter that fits. good air flow and traps more dirt and dust than screens, but filters are the better way to go , like a foam mushroom filter.
Old Jan 14, 2002 | 06:42 AM
falcongsr's Avatar
What is this crap?
Default Re: using screen on your turbo...good or bad..? (PLAYA HATIN HATA)
you guys are nuts.
Old Jan 14, 2002 | 07:50 AM
lucas569's Avatar
Default Re: using screen on your turbo...good or bad..? (falconGSR)
i wear womens nylons over my face when i go into banks,everyone gets real scared for some reason...
Old Jan 14, 2002 | 09:02 AM
turbopanda's Avatar
Default Re: using screen on your turbo...good or bad..? (lucas569)
I find I get more power from a K&N Cone filter rather than from an HKS foam mushroom filter. I've tried both. Seems like the K&N is less restrictive than the HKS ones.
Old Jan 14, 2002 | 09:13 AM
TurboSedan's Avatar
New User
Default Re: using screen on your turbo...good or bad..? (nathan's boosted civic)
K&N rulez!! I have an AEM CAI, and that K&N is going to be put to good use on the end of my turbo inlet!!!
Old Jan 14, 2002 | 09:57 AM
Smashback's Avatar
Foam filters suck. I have no idea why companies still make them. Companies like Edelbrock made them for carbed engines and proved they were good for three things:
1. Making less power than a K&N
2. Filtering worse than a K&N
3. Catching on fire when the engine backfires and shoots flames out the top of the carb!
Old Jan 14, 2002 | 10:19 AM
97integraLST's Avatar
Default Re: using screen on your turbo...good or bad..? (mplex2000)
I have been running Open = ( for the last 4 months.
Old Jan 14, 2002 | 10:26 AM
SiR Kid's Avatar
New User
Default Re: using screen on your turbo...good or bad..? (97integraLST)
My filtre looks like a filter on a stick.. it's just a tube the ame size as he turbo inlet about 6 inches long to put the filter right in front of the tranny
miahjera04
Dec 14, 2017 04:06 PM
rudebwoy
May 29, 2006 08:43 AM
madman604
May 27, 2003 02:13 PM
C-Murdock
Jul 21, 2002 03:12 AM
VTC_CiViC
Apr 24, 2002 09:46 PM
