Using a larger throttle body with boost worth it?
Old Aug 22, 2007 | 09:23 AM
jetlude's Avatar
Default Using a larger throttle body with boost worth it?
As the toppic says. I know on NA motors there is an advantage. How about with a turbo motor, are there significant gains by using a larger throttle boby?
Old Aug 22, 2007 | 09:26 AM
tony413's Avatar
Default Re: Using a larger throttle body with boost worth it? (jetlude)
depends 68mm-70mm seem to fit the needs of most anything over is mostly overkill and suffer from throttle repsonse in the low range
Old Aug 22, 2007 | 09:53 AM
jetlude's Avatar
Its for my H22. Dont remember the stock size, However I got one from the F20B which is a little bigger. Is it worth the swap ?
Old Aug 22, 2007 | 10:21 AM
JDMisGOOD's Avatar
Default Re: (jetlude)
What's your set-up?
Old Aug 22, 2007 | 11:27 AM
patrick4588's Avatar
ive always heard you should match the throttle body size with your cold side piping size.
Old Aug 22, 2007 | 12:26 PM
jetlude's Avatar
Default Re: (JDMisGOOD)
H22
sleeves
rods
pistons (9:1 Je)
60-1 turbo
etc etc
Old Aug 22, 2007 | 12:55 PM
if you have 2.5" cold side piping then i would go with a 64mm TB. if its 2.75" then go with 70mm
kte324
Feb 7, 2009 04:59 AM
jdm knight
Feb 8, 2008 08:19 PM
Kid_SiR
Jan 6, 2008 06:27 PM
Newbiemoney
Oct 29, 2005 07:40 PM
CRXRageD
Apr 19, 2002 08:48 AM
