Useful Information....
Old Oct 1, 2003 | 07:13 AM
4-banging's Avatar
Default Useful Information....
**You may know this already but I thought it would be useful to post**
This information is taken from the 2004 Edelbrock Sport Compact Catalog Issue.
INJECTOR SELECTION FORMULAS
Formula for converting from LB/HR to CC/MIN
CC/MIN = LBS/HR x 10.5
*Note on injector duty cycle:
Final engine configuration, a 90% duty cycle is acceptable.
Complete new engine build, use 80% duty cycle as a safety factor.
<U>_______________________________________________ _____</U>
To find the Max HP value of the injectors from (LBS/HR) on gasoline.
HP = [(Injector Size (LB/HR) x Duty Cycle) / BSFC] x # of Injectors.
*BSFC = Brake Specific Fuel Consumption
General: .50 to .55 BSFC
FI or SC: .55 to .60 BSFC
Methanol: 1.10 to 1.20 BSFC
Injector Size per HorsePowa
In general, if you use BSFC = .50 and an acceptale duty cycle of 85% on a 4 cylinder engine, then:
LBS/HR = HP / 6.8
Example:
You plan to make 240 HP. What size injectors should you use?
LBS/HR = 240 / 6.8
LBS/ HR = 35 LB/HR (use conversion formula to find cc/min)
CC/MIN. = 368 cc/min
OTHER FUEL FLOW FORMULAS:
Convert CC/MIN to LBS/HR: CC/MIN / 10.5
Convert LBS/HR to GPH: LBS/HR / 6
Convert CC/MIN to GPH: CC/MIN * .01585
...and finally
FORMULA FOR COMPRESSION RATIO
CR = Cyl Volume @ BDC / Cyl Volume @ TDC
= 1 + (Swept Volume / Volume @ TDC)
= 1 + [(0.7854 x Bore x Bore x Stroke) / 1000] / (CCV + HGV + PDV)
CCV = Combuston Chamber Volume in cc's.
HGV = Head Gasket Volume in cc's.
= Head Gasket Compressed Thickness in mm x 0.7854 x Bore x Bore / 1000
PDV = (Piston Deck Volume) + (Piston Dome Effective Volume)
= (0.7854 x bore x bore x Deck to Piston Distance) / 1000 + (Volume of Piston Depression - Volume of Piston Bumps)
Example:
What is CR of an engine if the heads have 42cc chambers, head gasket is compressed to 1mm and flat top pistons give 0.5mm deck clearance at TDC?
HGV = (1 x 0.7854 x 81 x 81) / 1000 = 5.2cc
PDV = [(1.5 x 0.7854 x 81 x 81) / 1000] + 0-0 = 2.6cc
CR = 1 + [(0.7854 x 81 x 81 x 87) / 1000] / (42 + 5.2 + 2.6)
= 10.0 CR
Feel free to add...
Y2K Si FBP
May 23, 2011 05:08 AM
Nikademo
Apr 22, 2010 01:46 PM
91CRXsiR
Apr 19, 2004 07:19 PM
vtec fan
Feb 3, 2004 10:49 AM
sparq
Jul 30, 2003 01:57 PM
