USDM or JDM ITR
Old Mar 25, 2004 | 04:33 PM
95DXCIVIC's Avatar
Default USDM or JDM ITR
Going to be buying an ITR from HMO in a couple weeks. Should I go with JDM or USDM? Gonna be going turbo when I get enough money for the kit...
Thanx
Old Mar 25, 2004 | 04:38 PM
-iLLuZioN-B18C1's Avatar
Default Re: USDM or JDM ITR (88CRXdude)
if you are set on getting an itr motor, go usdm.
CR slightly lower.
but why not just spend the money on a b18c1 and use the leftover money for your turbo stuff?
Old Mar 25, 2004 | 04:41 PM
warwagon's Avatar
Default Re: USDM or JDM ITR (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">if you are set on getting an itr motor, go usdm.
CR slightly lower.
but why not just spend the money on a b18c1 and use the leftover money for your turbo stuff?</TD></TR></TABLE>
what he said yo!!!!!!!
Old Mar 25, 2004 | 04:45 PM
95DXCIVIC's Avatar
Hmm, good question
Will there be a difference in the power if i go b18c1 instead of c5?(significant difference)
I'm gonna have about 4.5k to spend on the motor until i save some more..
What kind of things should i replace with whatever i go with, just to be safe before going turbo or will it be safe runnin boost on the stock engine...plan on runnin 7-9 psi as a daily driver.
Thanx
Old Mar 25, 2004 | 05:00 PM
B_1_8_hatch's Avatar
yeah....buy a c1 swap then buy a turbo kit with the left over money
Old Mar 25, 2004 | 05:02 PM
if you go C5, you will ultimately make more power per pound of boost. but then again, you have to make sure the tune is top notch, and every little thing counts.
with high CR, bad tank of gas could mean bad things for your motor. there is little room for error so to speak.
personally, id drop in a C1 motor, spend the rest on some parts for the turbo.
drive around the C1 for now. enjoy it while its unmodded
what type of power are you looking for?
how much do you want to spend on the turbo stuff?
are you loooking for a kit or custom?
street or track?
id start with the C1 and go from there.
Old Mar 25, 2004 | 05:13 PM
95DXCIVIC's Avatar
I want to try to make in the 12's eventually, swap is goin in a 88 CRX, and im going to probably buy a kit but not sure yet, havnt done much research on the turbo aspect of the swap, just know i want to go turbo in the future...going to be a daily driver but want to run at the track sometimes, what kind of things should i replace as well just to be on the safe side before boosting.. thanx guys for the feedback
Old Mar 25, 2004 | 05:21 PM
pgpunkguy's Avatar
you can save even more money by going with a b16a and putting a t3/t4 turbo on it...
i've seen it done for as little as $5 g's... 12's shouldn't be too hard to reach. my friend's crx had a b16 turbo and was running 12's on about 15lbs of boost.
Old Mar 25, 2004 | 05:24 PM
95DXCIVIC's Avatar
Default Re: USDM or JDM ITR (pgpunkguy)
is 15PSI on stock internals fine for at the track on a b18c1??20??
warwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">you can save even more money by going with a b16a and putting a t3/t4 turbo on it...
i've seen it done for as little as $5 g's... 12's shouldn't be too hard to reach. my friend's crx had a b16 turbo and was running 12's on about 15lbs of boost.</TD></TR></TABLE>
this is the truth, if i ever step to the b series i am gonna go with a 16 cuz they can make mad power YO!!
so you going with c1??
lets pretend you do.
with a good tuner and all the correct parts (dont go ghetto style )
youll be able to break into 12's with stock motor w/ slicks
you wont need any internal upgrades.
many people on this board have stock c1motors that easily hit 12's.
turbo parts if you decide to go custom
exhaust manifold
downpipe
turbo
BOV
wastegate
IC and piping
oil lines ect.
those are the main things
dont forget
engine management-hondata
injectors-do at least 550's
clutch
gauges-at least boost and egt
if your going kit..
depends how much your willing to spend...
if your a big baller go with full-race , all quality parts in there kit
if not, id do revhard.
Old Mar 25, 2004 | 05:26 PM
well, since we are talking about all motors now, just throw in a b18b motor.
awesome power and lots of torque.
cheap to buy new block too if it blows
Old Mar 25, 2004 | 05:35 PM
95DXCIVIC's Avatar
thanx guys for the help, im gonna be goin c1 for sure...
I probably am going to buy a kit, almost definantly since this is my first time doin anything w/ turbo so not sure about all the stuff and wats good/ not...
wat are the price ranges ont he revhard/fulldrag, and where are good places to buy them.
also one more Q, not really FI but wth, am i going to be able to drop in the gsr w/ the mounts that come with the HMO package?? or will have to make some modifications?
Thanx
Old Mar 25, 2004 | 06:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88CRXdude &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys for the help, im gonna be goin c1 for sure...
Thanx </TD></TR></TABLE>
i am almost 100% sure you will need motor mounts. search around in the HYBRID forum. im sure plenty of people have done this swap.
for revhard, check out kyles website, awesome seller, great customer service and price
http://www.wiredspeed.com/
full-race is very pricey. but check out there stuff.
http://full-race.com/pd_turbokits.html
Old Mar 25, 2004 | 06:57 PM
Muckman's Avatar
Moderator in Chief
I have a fully rebuilt B18C1 swap for sale actually
Old Mar 25, 2004 | 07:04 PM
b_jamin's Avatar
if your gonna go with a b series swap in your crx you will need to buy a mount kit...i found hasport has one of the best mount kits and place racing is equally good. but they can get pricey...i don't know how much they are now but they were like 500 last time i bought one(3 year ago maybe more). good luck with it though
Old Mar 26, 2004 | 05:41 AM
pgpunkguy's Avatar
Default Re: USDM or JDM ITR (b_jamin)
for crx, HASPORT
Old Mar 26, 2004 | 06:40 AM
95DXCIVIC's Avatar
yah i looked that up last night, and found hasport makes the mounts...they about 500 dollars but their stuff is recomended by a lot of peeps so gonna go with them to put it in.
Thanx guys for the help
Old Mar 26, 2004 | 08:56 AM
pgpunkguy's Avatar
yeah, good stuff don't come cheap!
90teg
Aug 25, 2005 07:46 PM
noxlovexhere
May 4, 2005 04:15 PM
Declectic
Aug 30, 2004 07:49 PM
eg_nezay
Jan 7, 2003 06:02 PM
.Ryan
Sep 10, 2002 02:59 PM
