urget h22 Question
Old Jan 22, 2005 | 05:55 PM
Phat8186's Avatar
Default urget h22 Question
Ok I have a 2000 h22a4 motor.
I just finished getting the bottom end built ( Darton M.I.D Kit Sleeves, JE 9:0.1 pistons, Scat forged rods, Crank micropolished and balanced )
For my turbocharged application that I am planning for.
As for as the head it is stock for now, but will be going with the whole Crower turbo cams and full valvetrain.
Here is my prob, I have a 96 accord ex sedan, and the motor finally decided to **** the fan. So now I am rushed to drop the H22a4 in as is but have not yet finished buying all the turbo crap.
My question is can I break in this motor in N/A on the JE 9:0.1 pistons on a P13 ECU without harming my engine. Since when I do go turbo I have to use a p28 ECU since it can be tunable.
I also do realize that I think I have to get an obd2b - obd1 conversion harness is this correct in saying so.
Please any help will be greatly appreciated.
Old Jan 22, 2005 | 06:00 PM
Finest's Avatar
Default Re: urget h22 Question (Phat8186)
You can run it off the stock ECU for N/A purposes. You'll probably feel a little loss in low end due to the lowered compression.
You can use either an OBD-I or OBD-II ecu, just make sure to get the matching distributor and fuel injectors to the correct OBD ecu. (OBD-1 = Peak and Hold, OBD-II = Saturated)
Old Jan 22, 2005 | 06:03 PM
ItzTw's Avatar
wait till you have all your turbo stuff. take it straight to have it tuned. don't even start it.
Old Jan 22, 2005 | 06:31 PM
prelittlelude's Avatar
Default Re: urget h22 Question (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">You can run it off the stock ECU for N/A purposes. You'll probably feel a little loss in low end due to the lowered compression.
exactly, you will be fine to break it in n/a, there is no reason to rush the turbo setup on to it. just make sure you run stock injector size for the stock ecu
i ran a 9:1 setup for a while on the stock p13, it killed me though because i had no knock sensor, so i always had a cel and less ignition timing. just make sure all the sensor the stock ecu will look for are there and your golden
Old Jan 22, 2005 | 06:36 PM
Phat8186's Avatar
Default Re: urget h22 Question (ItzTw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItzTw &raquo;</TD></TR><TR><TD CLASS="quote">wait till you have all your turbo stuff. take it straight to have it tuned. don't even start it.</TD></TR></TABLE>
I wish I could wait and not even start it yet. But as stated my old engine kicked the bucket and I have no car right now. So there for I have no choice.
Old Jan 22, 2005 | 06:42 PM
Phat8186's Avatar
So this can be done then. I just have to make sure that I now get an OBD1 Dizzy along with OBD1 peak hold injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly, you will be fine to break it in N/A, there is no reason to rush the turbo setup on to it. Just make sure you run stock injector size for the stock ecu
I ran a 9:1 setup for a while on the stock p13, it killed me though because I had no knock sensor, so I always had a cel and less ignition timing. Just make sure all the sensor the stock ecu will look for are there and you’re golden </TD></TR></TABLE>
Why wouldn’t I have a knock sensor is that cause of the p13 ecu I am a little lost
I also want to say thanks to everyone that has posted. It is very much appreciated
Old Jan 22, 2005 | 07:21 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phat8186 &raquo;</TD></TR><TR><TD CLASS="quote">Why wouldn’t I have a knock sensor is that cause of the p13 ecu I am a little lost
I think what he meant was that he didn't have a knock sensor hooked up, so his car wasn't running right. You'll be okay running it "stock". Good luck on the turbo setup in the future.
Old Jan 23, 2005 | 07:16 PM
I think what he meant was that he didn't have a knock sensor hooked up, so his car wasn't running right. You'll be okay running it "stock". Good luck on the turbo setup in the future. </TD></TR></TABLE>
correct, this is what i ment, but you should be all good
zaida08bk
Jul 22, 2015 11:33 PM
Jamm_95
Nov 14, 2014 08:10 PM
94lsvtec
Jul 19, 2008 06:56 PM
djnikko
May 14, 2005 10:27 PM
