!urgent! need part number for apex map sensor
Old Sep 8, 2006 | 08:48 PM
nz_turbo_type_r's Avatar
Default !urgent! need part number for apex map sensor
as topic states, please help me out, i know someone knows, i need an apex map sensor to run on my jdm 97 itr running power fc
thanks in advance
Old Sep 8, 2006 | 09:40 PM
F20Cteg's Avatar
Default Re: !urgent! need part number for apex map sensor (nz_turbo_type_r)
2 second search got me APE499-X001 for 3 bar.
Old Sep 8, 2006 | 11:24 PM
Default Re: !urgent! need part number for apex map sensor (F20Cteg)
top man! you should work for apex here in nz! cheers for the help, anyone know if there is a specific wiring harness or just use factory?
Old Sep 9, 2006 | 01:02 AM
TheShodan's Avatar
Moderator
You must also get the full boost kit which comes with the harness to plug directly into your Power FC.. It does not get wired into the internal harness like a GM style 3 bar, since it works IN CONJUNCTION with your stock map sensor, so don't get rid of it!!!
raleylund
Oct 18, 2007 12:29 PM
93dabeast
May 23, 2007 04:24 AM
qwklude82
Jan 8, 2003 09:43 PM
joeyitr309
Oct 21, 2001 12:04 PM
