Urgent: how to wire an inline fule pump...help pleae
Old Oct 27, 2001 | 05:49 PM
DIRep972's Avatar
Smarter than you
Default Urgent: how to wire an inline fule pump...help pleae
okay, I am flamenco and I am installing my Drag kit with Direp972.
can anyone tell me how to install the airtex fuel pump from the drag kit ?
the instruction on importparts wasn't clear to me....
can anyone help ?
thanks
stan 817-723-2526
Old Oct 27, 2001 | 07:40 PM
udctown's Avatar
New User
Default Re: Urgent: how to wire an inline fule pump...help pleae (DIRep972)
well i can sort of help you in terms of wiring.
for the 12v wire you are going to have to go through your firewall. the fuel pump relay is underneath the driver side dash. you will see the fuse relay box and then the main fuel pump relay is to the left of that. it is hanging down and held on by a 10 mm bolt. there are only eight connections coming out of the back of the relay. the main fuel pump is yellow/green i think. i would check a haynes or helms manual. if you don't have one let me know and i'll look it up for you in my haynes.
in terms of ground i think you can ground it to the engine. my buddy did that part for me so i would have to look it up but it should just ground to your engine and the necessary parts should come with your kit. if you have any other questions you can im me at ud ctown on aol. good luck
Old Oct 28, 2001 | 04:37 AM
integRated109's Avatar
you can ground it anywhere, mine was just bolted to the shock tower.
Old Oct 28, 2001 | 08:04 AM
DIRep972's Avatar
Smarter than you
Default Re: Urgent: how to wire an inline fule pump...help pleae (udctown)
so al I have to do is tap the red(12v wire) to the (farthest left /green and yellow wire) and the ground wire to any grounds ???
how do I "install" the pump, as far as cutting the fuel lines ?
I know I have to do it after the fuel filter, and afterward, I really have no clue...
I have the airtex from the Drag kit btw....
thanks for the help in advance
Old Oct 28, 2001 | 10:38 AM
chri5's Avatar
cut the fuel line that runs from the fuel filter to the fuel rail. The inline pump will go in between the two. The brass fitting that goes from 1/4-3/8 will go before the fuel pump, and will connect to the little stub of the original 1/4 fuel line that you left. you know what...diagram time.
[fuelfilter]--[stock1/4"hose]--[brass1/4-3/8fitting]--[3/8hose]--[fuelpump]--[stock1/4"hose]--[fulerail]
Old Oct 28, 2001 | 06:50 PM
Flamenco-T's Avatar
Default Re: Urgent: how to wire an inline fule pump...help pleae (Chris_Turbo)
Chris turbo: I got it, Thanks
but how did you mount your pump, I tried to mount it, and the banjo fitting on the fuel filter is facing the driver side so any attempt to move the pump to the firewall on the passenger side will be choking the lines since the banjo is pointing the opposite way....
hwo did you do it, is longer fuel lines the ONLY solutions ?
tia
Old Jun 6, 2006 | 07:06 PM
Flamenco-T's Avatar
Default Re: Urgent: how to wire an inline fule pump...help pleae (Flamenco-T)
Chris,
Connect the port that has a + to a 12 V (positive) RED source on the battery and the port that has - to the negative port (black) on the battery.
Make sure you don't do it backward, otherwise, you'll lose power and it will ran so loud and you can not hear anything
stan
Old Jun 6, 2006 | 07:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">Chris,
stan</TD></TR></TABLE>
You made this post under chris' name and you respond to yourself?
Old Jun 7, 2006 | 08:28 AM
AIRIC's Avatar
Default Re: Urgent: how to wire an inline fule pump...help pleae (Arturbo)
most confusing thread ever
Old Jun 7, 2006 | 08:35 AM
Turbocivic94's Avatar
You ******* get a job j/k hahah
Old Jun 7, 2006 | 08:40 AM
notoriousB's Avatar
this thread is confusing, who is who now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">hwo did you do it, is longer fuel lines the ONLY solutions ?
that's how I had to do it years ago when I ran the airtex pump on my drag kit
Old Jun 7, 2006 | 08:43 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Urgent: how to wire an inline fule pump...help pleae (notoriousB)
LOL, solutions..
Old Jun 7, 2006 | 11:24 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">LOL, solutions..</TD></TR></TABLE>
Sorry, I am a new memember of the english speaking community...
stan
civic89si666
20
Dec 21, 2009 10:25 PM
hatchback_al
Oct 26, 2004 10:00 AM
rice4life
16
Sep 4, 2002 12:39 PM
echo999
Oct 15, 2001 05:00 PM
