upper hp limit of .63 ar 57 trim
Old Sep 1, 2008 | 06:13 AM
blackeg's Avatar
Default upper hp limit of .63 ar 57 trim
actually thinking of putting a 57 trim on my motor with .63 ar exhaust housing.
whats the upper limit of that exhaust housing before i should try and find an 82 ar?
my motor is an 84x89vtec, 01 itr cams and valvetrain, victor x im using a miniram mani, 44mm gate and full 3" exhaust
Old Sep 1, 2008 | 09:06 AM
TheShodan's Avatar
Moderator
Default Re: upper hp limit of .63 ar 57 trim (blackeg)
You'll get about 20 more hp or so from the .82A/R but at max about 435whp. Get a larger turbo after that point.
Old Sep 1, 2008 | 10:04 AM
narfdanarf's Avatar
Default Re: upper hp limit of .63 ar 57 trim (TheShodan)
Mine makes 500ish on 30lbs on a pistons/rods b16. I wouldn't recommend that though, it's way out of it's efficiency range and it's workin mighty hard and now it's starting to smoke a little after about 20kish miles. I agree with Shodan, if you want more than 435-450 then find something else.
Old Sep 1, 2008 | 05:31 PM
non-VTEC's Avatar
my t3/t04b 57trim .63 made 420whp@17psi.
great turbo with the right setup and tuning....underestimated by most users.
blackeg
Oct 23, 2011 02:21 PM
b.serious
Aug 14, 2006 02:50 AM
turtle-eg
Jan 2, 2005 07:35 PM
egg
May 2, 2003 04:30 PM
