MBC vs Spring target boost
Old Oct 12, 2013 | 07:39 PM
carlos8's Avatar
Default MBC vs Spring target boost
Hi guys, I am having problems with a cheap MBC with boost spike. What is more effective buy a good MBC or go directly to my target boost via spring.
My car is tuned at 17psi, so a Large green + small Yellow = 16.7 psi.
or hallman or voodoo MBC with ceramic ball.
thanks in advance
Carlos
Old Oct 13, 2013 | 05:58 AM
Freemananana's Avatar
Default Re: MBC vs Spring target boost
thanks in advance
Carlos
I like running directly off of the wastegate pressure. I forget why people don't like to do that, there is some reason. But that's my preference. It's what I plan on doing.
Old Oct 13, 2013 | 06:08 AM
motoxxxman's Avatar
I prefer spring pressure as well, but if you want a MBC, I recommend the Hallman
Old Oct 13, 2013 | 08:32 AM
TheShodan's Avatar
Moderator
Better to use a hallman. When going strictly by target spring, please remember, it will start to open just before target boost pressure to avoid a spike. So if you have a 7 psi spring, it will open at about 6.8 psi if the boost reference source is not too strong, otherwise it will slightly overboost. For under $80, its a MUCH better alternative than making a guess.
Old Oct 13, 2013 | 10:05 AM
carlos8's Avatar
Thanks guys, Bought a Hallman this morning on ebay.
1990hondaHF
Jan 16, 2008 11:57 AM
vg7z
Sep 20, 2006 08:27 PM
TurboDANDEE
Nov 16, 2003 12:31 PM
zojirushi
Jan 23, 2002 04:42 PM
