upgrade springs without valves?
Old Apr 12, 2012 | 01:24 PM
98integralsB18's Avatar
Default upgrade springs without valves?
hey guys I had a quick question I have a stock ls head with a built bottom end on my turbo integra. I wanted to see if i can get a little more revs out of it instead of stopping at 7grand. I would like to rev to 8000 or 8200 somewhere in that area. Trying to get a longer power band. Was wondering if I could just upgrade the springs and leave the stock valves in or would I have to do both for my rpm target.
Old Apr 12, 2012 | 01:33 PM
2000GSRTypeR's Avatar
Default Re: upgrade springs without valves?
That is exactly what I am doing on my GSR head. I am only upgrading the valve springs and retainers and reusing the stock valves. There is nothing wrong with the stock valves.
Old Apr 12, 2012 | 01:35 PM
Would i have to upgrade my retainers too? because a vtec head revs to 8200 from the factory without TI retainers.
Old Apr 12, 2012 | 01:38 PM
TheShodan's Avatar
Moderator
If the cylinder head doesn't have enough CFM flow to it, like an LS, "revving" higher won't necessarily net you more power. Look at the turbocharger and the rest of the setup that you're using now before deciding to go "higher".
Your stock valves will be fine.
Old Apr 12, 2012 | 01:47 PM
Thanks Shodan! I have a hy35, drag-gen 3 IC, 2.5 charge pipes, blox Intake mani, stock TB. I would just rather be able to have more revs especially because I do not build boost till later in my rpms. So if I just upgraded my springs I would be okay? No need for retainers?
Old Apr 12, 2012 | 05:07 PM
anyone do i need to upgrade retainers as well or will i be fine with just springs?
Old Apr 12, 2012 | 05:14 PM
Turbo-LS's Avatar
You will need springs and retainers. Stock valves are fine but you will need cams as well. Just raving an engine higher doesn't make more power you have to accompany that with the right modifications. Cams for sure and maybe an intake manifold unless your on a p75 intake then should be ok
Old Apr 12, 2012 | 05:32 PM
yeah, I have a manifold, i know i should do cams etc. but me reving my motor higher if I'm still making power is what I'm getting at i guess. I'm trying to go 400 so I will be building a decent amount of boost and rather not be at full boost for 2 grand haha my HY35 starts spooling at like 3600 and i build 15psi around 4200 if i remember right. Havent drove it for about 9 months now. I do not have the money for cams and everything right now but just wanted to rev a little higher than 7 grand. unless 7500 7800 is okay, which i think i remember seeing it somewhere 7500 is really the highest.
Old Apr 12, 2012 | 06:38 PM
Turbo-LS's Avatar
I really don't think it's going o happen on stock cams and that turbo but good luck
Old Apr 12, 2012 | 06:45 PM
thank you. If i upgrade springs and plan to rev to 8 grand will the stock retainers work?
Old Apr 12, 2012 | 06:55 PM
Turbo-LS's Avatar
No get retainers
Old Apr 12, 2012 | 07:01 PM
okay, thank you for your input sir!
Old Apr 19, 2012 | 10:21 AM
Got another question about this, I'm in college so i don't have much money left in my car fund but, my buddy has gsr springs and retainers he is not using would i be able to put them into my ls head intake and exhaust side for a slight upgrade and rev a little higher is needed?
Old Apr 19, 2012 | 10:36 AM
kyden's Avatar
no.
herde1724
Jan 27, 2005 11:41 PM
Agip
Jan 18, 2005 08:18 PM
quick1racer
Jul 14, 2004 05:40 PM
PrecisionH23a
Apr 26, 2002 08:36 PM
