UPDATE: TRACK TIMES
Old May 6, 2007 | 07:40 PM
94whtgsr's Avatar
Default UPDATE: TRACK TIMES
Well I finally made it home from school to run the car with the new power..... i had many runs in the mid 12s around 128mph.... but the best of the day was
All runs were made on pump gas the same numbers as shown before as well as on 15"rotas with Falken Azenis.... also still stuck with the open diff... lemme know what you all think....
R/T .137
60' 2.122
330' 5.717
1/8 8.416
MPH 96.84
1000 10.581
1/4 12.343
MPH 131.32
I had another thread with my numbers and setup but heres what you need to know....
First off my setup:
B18c1 81mm stock sleeves
cp 9.0:1
Crower rods
ARP head studs
stock gsr head with supertech valve springs and retainers and ctr cams
AFI ramhorn manifold and 3" downpipe
Tial 44mm WG
Precision SC6176e
Hondata S300
Precision 1000cc
Walbro 255lph
OEM fuel lines and filter
open diff
thats the basic rundown
Tuned by Josh at Raceline in Cincinnati
The boost is currently at 20lbs running off the wg spring... These are all mustang dyno numbers and all on 93 octane from UDF
The car made 478whp and 310 tq but was richened up a bit for saftey concerns and is making closer to 460whp
Old May 6, 2007 | 07:43 PM
Widebody1's Avatar
Good stuff Jeffrey!!!! Impressive for Pump gas for sure
Old May 6, 2007 | 07:49 PM
rmcdaniels's Avatar
Default Re: UPDATE: TRACK TIMES (94whtgsr)
That trap speed is great, but you really need some tires, looks like a fun car.
Old May 6, 2007 | 07:51 PM
94whtgsr's Avatar
yea for sure... the track isnt the greatest but i just didnt have the money for wheel bearings and studs to go with the big slicks...
Old May 6, 2007 | 07:54 PM
rmcdaniels's Avatar
Default Re: (94whtgsr)
Even a set of Hoosier DR's, which mount on Rota 15's, should get you deep in the 11's.
Old May 6, 2007 | 07:57 PM
jdizzle!
Guest
Posts: n/a
Default Re: (rmcdaniels)
get a decent tire on there! nice times though
Old May 6, 2007 | 08:01 PM
Widebody1's Avatar
azenis are decent tires, and this was the first time those hit the pavement... Its the track, noone around here gets the ET's that other people do around the country
Old May 6, 2007 | 09:28 PM
mighty137's Avatar
I'd bet u were roasting them tires from 1st till the end of 4th.
I ran a very similar time to u as well, but with BFG drag radials.
Great time though, especally the trap speed!
BTW what psi was ur tires at???
Old May 7, 2007 | 08:43 AM
94whtgsr's Avatar
tires had 15-16lbs of air in them..
Old May 7, 2007 | 09:05 AM
92HB_HB's Avatar
that's moving ..!! I'll be at the track this thursday.. hope to have my boost issues solved so I can run some consistant times too..
i was trapping 116 on low boost .. ~ 11 psi
Old May 7, 2007 | 09:06 AM
GetawayInMoscow's Avatar
A 2.1 60' out of street tires is great. I don't know what else the hell you guys are expecting.
Old May 7, 2007 | 09:14 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">A 2.1 60' out of street tires is great. I don't know what else the hell you guys are expecting.</TD></TR></TABLE>
Sixty-foot times are not the mitigating factor when you're putting down almost 500whp. If he's trapping 130mph and only running a 12.4, he needs slicks to make the most out of his setup. He can run 12.4's at 130+ or he can run 11.2 at 125 with slicks A 2.1 60' is fantastic for that amount of power on street tires, but when they spin at the top of every gear, you're losing precious ET.
Old May 7, 2007 | 10:19 AM
94whtgsr's Avatar
yea for sure... the car has gone 11.6@125 on 22" slicks, with a 2.0 60ft as well... also the car had about 60 less whp, the numbers are in my sig... i will definitely have slick times this summer when im home from school.... i was just pumped about the trap speed...
Old May 7, 2007 | 10:57 AM
g2turbo's Avatar
not bad man. For comparison my car made 438 whp 285tw on a Dynojet.
On 215/60/14 BFG drag radials my best pass was
RT-.502
60-2.076
330-5.535
1/8-8.095
MPH-99.93
1000-10.251
1/4-12.037
MPH-127.35
RT-.029
60-2.077
330-5.588
1/8-8.241
MPH-97.38
1000-10.438
1/4-12.248
MPH-125.76
My tire pressure was 10 psi hot. I was running 18psi in every gear for lack of boost control.
The key to running fast on these drag radials is getting them very hot and setting up boost so that you dont spin too badly.
Have you guys messed with the hondata boost control yet? Its supposed to work really well. That will help get your short track times down quite a bit im sure. Then the car should definitely have 11's no problem.
Did the car spin bad in 1st and 2nd?
Modified by g2turbo at 12:56 PM 5/7/2007
Old May 7, 2007 | 11:24 AM
Topdawgg's Avatar
badass times for street tires.... good job man..
i was only gettin 1.9/2.0 60 ft times with my hatch makin 320whp on 22 inch slicks..
Old May 7, 2007 | 11:43 AM
93supercoupe's Avatar
Default Re: (Topdawgg)
128 is definatly good for low 11's.
Pump gas FTW
Old May 7, 2007 | 11:58 AM
g2turbo's Avatar
Default Re: (93supercoupe)
azenis are a true street tire arent they? My comparisons dont count lol. For some reason I thought he was running a drag radial.
Old May 7, 2007 | 12:31 PM
aaronISthrowed's Avatar
Default Re: (g2turbo)
Good times for a street tire.
Old May 7, 2007 | 12:35 PM
THEDirtyDseriesWOOT's Avatar
i wetn 13.3 @120 on my azenis when i had 280whp thay are ok of a tire .. but i slappe don some slicks and ran a 12.3 @116
ijust ran 11.4@127 i wonder what i would trap with my azensi ----
Old May 7, 2007 | 03:07 PM
94whtgsr's Avatar
we had originally tried the boost control with hondata but no matter what we did, it wouldnt control the boost... and yes it spun all of 1st and 2nd....
Modified by 94whtgsr at 12:34 AM 5/8/2007
Old May 8, 2007 | 11:28 AM
94whtgsr's Avatar
ill just have to wait til the honda-tech weekend with slow motion to run at a good track... ive ran at national trails before with much better luck on street tires...
Old May 8, 2007 | 11:42 AM
IntegraGSR-Turbo's Avatar
with a better 60' you could have hit 11's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94whtgsr &raquo;</TD></TR><TR><TD CLASS="quote">Well I finally made it home from school to run the car with the new power..... i had many runs in the mid 12s around 128mph.... but the best of the day was
R/T .137
60' 2.122
330' 5.717
1/8 8.416
MPH 96.84
1000 10.581
1/4 12.343
MPH 131.32
First off my setup:
cp 9.0:1
Crower rods
ARP head studs
Tial 44mm WG
Precision SC6176e
Hondata S300
Precision 1000cc
Walbro 255lph
open diff
Old May 8, 2007 | 12:43 PM
94whtgsr's Avatar
ha no ****
luck4rmkc
Mar 7, 2011 05:03 PM
johnson_racing
Oct 18, 2009 05:02 PM
94whtgsr
Apr 16, 2007 11:20 AM
tthame1
May 2, 2005 01:00 PM
jcivicsib20
Feb 10, 2003 11:22 AM
