Update: Block Posting
Old Jul 2, 2002 | 09:58 AM
Sonny's Avatar
25 Year Member
Default Update: Block Posting
This is a followup to this thread:
https://honda-tech.com/zerothread?id=212676
I don't have my block back yet, but here are the posts that I had a machinist friend of mine make for me. He did a bitchin' job!
Sonny
Old Jul 2, 2002 | 10:39 AM
eddie1681's Avatar
New User
Default Re: Update: Block Posting (Sonny)
looks good sonny
Old Jul 2, 2002 | 11:30 AM
*Boostwerks*'s Avatar
What is the red paper for?
Look's Good!
Can't wait to see them in the block.
Old Jul 2, 2002 | 11:47 AM
Tomakit's Avatar
Default Re: Update: Block Posting (Bryson)
Reference to see just how large the posts are, I'm guessing.
Tom
Old Jul 2, 2002 | 01:01 PM
Sonny's Avatar
25 Year Member
Default Re: Update: Block Posting (Tomakit)
Tom
Yeah, it's just a reference. I picked up the block today during lunch. The machinist did a great job. I'll take some pics tonight.
Sonny
Old Jul 2, 2002 | 01:07 PM
Arturbo's Avatar
Better than steak
25 Year Member
Look's Good!
Its block post it notes, or is is block posting? I get the 2 mixed up.
Old Jul 2, 2002 | 01:27 PM
ThePunk's Avatar
Default Re: Update: Block Posting (Arturbo)
That looks like a ESD mat underneath everything..
<---My contribution to the notice everything but the actual intent of the photo routine.
Old Jul 2, 2002 | 01:32 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Update: Block Posting (ThePunk)
D, I think you are right about that one.
Old Jul 2, 2002 | 01:41 PM
Sonny's Avatar
25 Year Member
Yep, it is an ESD mat. I took the pictures at work. Right now the block is on a bench in the lab. I hope nobody complains.
Anyway, here are the pics. They are big, but I wanted everyone to see the gory details.
Sonny
Old Jul 2, 2002 | 01:45 PM
SlowB16's Avatar
Call me an idiot, but what does "block posting do"? It looks like it hold the cylinders in place but......
Old Jul 2, 2002 | 01:47 PM
pbomers's Avatar
Default Re: Update: Block Posting (SlowB16)
looks good....you should sell sets of those posts....
Old Jul 2, 2002 | 01:52 PM
eddie1681's Avatar
New User
sonny it looks good, how much did it cost for the the drilling and tapping of the block?
I notice that you are using only 12 post, is there a reason for that?
BTW how do you get clean the rust off the cylinder wall?
Thanks
Old Jul 2, 2002 | 02:12 PM
Sonny's Avatar
25 Year Member
Default Re: Update: Block Posting (b20z)
Thanks
Drilling/tapping the holes was $100 at the local machine shop.
I put 12 posts in the block at the locations that Larry @ Endyn told me to use.
The cylinders will get cleaned out when the block goes in for boring/honing to get the pistons fitted.
Sonny
Old Jul 2, 2002 | 02:27 PM
TurBoXBirD16's Avatar
what does this posting do??
i don't get it
what's the benefits??
good job anyways hehe
Old Jul 2, 2002 | 02:32 PM
Sonny's Avatar
25 Year Member
Default Re: Update: Block Posting (xbird)
Posting and blockguards are an economical way to reinforce the block when subjecting them to lots of boost. Resleeving is the "ultimate" way to do it, but new sleeves are very costly.
Sonny
Old Jul 2, 2002 | 02:35 PM
OH, so you are using those studs to "force" the sleeves not to EXPLODE or break
but only 2 studs on ONE side, is that enough???
thanks
Old Jul 2, 2002 | 02:42 PM
ElectronMan's Avatar
What is meant by "lots of boost" ? Just curious what amount of boost warrants this type of mod.
Old Jul 2, 2002 | 03:17 PM
Sonny's Avatar
25 Year Member
Default Re: Update: Block Posting (ElectronMan)
I plan on running 15 to 20 psi of boost. People regularly run 10-12 psi on stock sleeves. Some people who are really on top of their tuning have gotten away with more than that on stock sleeves. However, since the engine was already torn apart, I figured that I might as well reinforce it.
Sonny
Old Jul 2, 2002 | 03:18 PM
There are 2 stud's per cylinder on ONE side + 1 stud per cylinder on the other.
The amount of boost you can run depend's on so many other thing's it's not worth giving you an awnser, but I can say that they Should hold around 20psi.
Old Jul 2, 2002 | 05:12 PM
Zeus's Avatar
Never really talked to Larry about it, but I was worried about the long term effects of thermal expansion working on the sealant your going to use on the posts... I'm sure you asked that of him Sonny, what'd he say?
Old Jul 2, 2002 | 08:20 PM
DigitalFusion's Avatar
Default Re: Update: Block Posting (Zeus)
Sonny,
A couple qwik Q's for ya:
1.) are those studs the same aluminum alloy as the block? What alloy is it?
2.) How much do you torque the studs to?
3.) Where in the heck do u get Dev Con liquid aluminum, and how much is it?
4.) I know you got where to tap the block via Larry, but how does one determine this? Would those locations work just as well on a B Series?
5.) Do u know anything about endyn's forum? I have been outta the technical areas for about a year, I can back and the forum is down. The email address is have my SN registered under is no longer valid, so maybe i missed something?
Old Jul 2, 2002 | 09:42 PM
Sonny's Avatar
25 Year Member
Hey Zeus: Long time, no see. As far as the sealant coming loose, he said not to worry. He said that there are many people who have been running the same setup for years without problems. A couple of guys here (-TJ and Jeff) report no problems with sealing after extended use. TJ said that his block has been working fine for several years now.
Sonny
[Modified by Sonny, 6:03 PM 7/4/2002]
Old Jul 3, 2002 | 02:52 AM
Zeus's Avatar
thanks Sonny... been spending more time on the Type R forum these days... but to much squabbling on the boards these days to post too often... too many clean fingernails preaching to the dirty...
[Modified by Zeus, 5:53 AM 7/3/2002]
Old Jul 3, 2002 | 06:01 AM
falcongsr's Avatar
What is this crap?
wow. what an excellent statement. that pretty much sums it up.
Old Jul 3, 2002 | 06:37 AM
Speed PHreak's Avatar
Default Re: Update: Block Posting (falconGSR)
too many clean fingernails preaching to the dirty....
Ha ha ha, my nails are always dirty. Kinda embrassing in a businees work enviroment
Good work on the block posting sonny. If I wasn't such a puss, I wouldn't mind doing it to my block. But the LS turbo is kinda "shoe-horned" into my CRX
