Uh, Oh....
Old Sep 25, 2002 | 09:24 AM
madman604's Avatar
Default Uh, Oh....
Last night I re- installed my factory injectors to fix an over rich problem i had (running RC 310) and i re did all my vaccuum lines and installed my boost controller.
Anyways the car ran great then as i adjusted the boost controller then went for a test run. obviously i turned the boost too high and when i floored it the boost guage hit 15psi for a second then the car let out a huge black cloud out the exhaust and it felt like i hit a brick wall.
i let off as soon as i saw the overboost and the smoke went away instantly. nothing seems wrong and the car still drives fine with no apparent problems or noise.
now, is there something i shoud be looking for (besides an electronic boost controller?) currently its running at 10 psi.
is my headgasket toast?
Old Sep 25, 2002 | 09:30 AM
SIK IN DA HED's Avatar
New User
Default Re: Uh, Oh.... (Turbo E)
whoa... thats a close call there, man. i was thinkin you might have blown something. run a compression check and see what you get across the board.
Old Sep 25, 2002 | 09:37 AM
shadowdawn's Avatar
Default Re: Uh, Oh.... (dlplayboy)
I hate doing compression tests.... its like waiting to see if your dearly loved cat or dog has cancer......
Old Sep 25, 2002 | 10:05 AM
ion_four's Avatar
Default Re: Uh, Oh.... (shadowdawn)
If you're running at normal vacuum (22-18in hg) at idle, doesn't that mean that you're good?
Old Sep 25, 2002 | 11:08 AM
madman604's Avatar
Default Re: Uh, Oh.... (ion_four)
yah, i have good vaccuum -18hg. Am I ok?
rdeezy78
Aug 27, 2007 03:19 PM
turbolude99
Feb 9, 2006 06:50 PM
choiboiracing
Jan 30, 2004 12:52 AM
LOwrestling2001
Sep 4, 2002 10:54 AM
