Uberdata users check in here!
Old May 15, 2005 | 03:45 PM
Rocks
Guest
Posts: n/a
Default Uberdata users check in here!
Can you please let me know how well it worked for you, what problems you ran across, either from the program or user error. Thanks! Oh and please let me know if you used it on NA and FI'ed cars. Thanks
Old May 15, 2005 | 04:27 PM
Enzo Speed's Avatar
Default Re: Uberdata users check in here! (Rocks)
Works great. Shooting for 400whp on new SOHC turbo setup @ uberdata.
And there are a million and one problems with the software, listing them all would take days. You have to figure out which versions work with your ECU. My car runs on a P28 so the two versions I use are 1.70 and ost2.
Also, datalogging is a horrendous bitch to setup. If I were you I would buy the $35 cable from moates.net. It elimintates many of the variables that keep datalogging from working.
Old May 15, 2005 | 09:55 PM
Rocks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks &raquo;</TD></TR><TR><TD CLASS="quote">Can you please let me know how well it worked for you, what problems you ran across, either from the program or user error. Thanks! Oh and please let me know if you used it on NA and FI'ed cars. Thanks</TD></TR></TABLE>
Old May 15, 2005 | 10:10 PM
SOHC_MShue's Avatar
Default Re: Uberdata users check in here! (QuagmireII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuagmireII &raquo;</TD></TR><TR><TD CLASS="quote">Works great. Shooting for 400whp on new SOHC turbo setup @ uberdata.
Also, datalogging is a horrendous bitch to setup. If I were you I would buy the $35 cable from moates.net. It elimintates many of the variables that keep datalogging from working.</TD></TR></TABLE>
actaully setting up the datalogging cable isn't very hard at all. I bought a $10 nokia cable off ebay, soldered it in, plugged it up, and it worked great. You must have done something wrong.
Old May 15, 2005 | 10:23 PM
QuagmireIII's Avatar
Default Re: Uberdata users check in here! (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
actaully setting up the datalogging cable isn't very hard at all. I bought a $10 nokia cable off ebay, soldered it in, plugged it up, and it worked great. You must have done something wrong. </TD></TR></TABLE>
Well sometimes the cables don't work (mine) and sometimes the drivers don't download right from pgmfi.
BTW, how come you didn't respond to my thread that was basically directed at you? Bitch
Old May 15, 2005 | 10:37 PM
SOHC_MShue's Avatar
Default Re: Uberdata users check in here! (QuagmireIII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuagmireIII &raquo;</TD></TR><TR><TD CLASS="quote">Well sometimes the cables don't work (mine) and sometimes the drivers don't download right from pgmfi.
BTW, how come you didn't respond to my thread that was basically directed at you? Bitch </TD></TR></TABLE>
sorry man i haven't been in the datalogging section on the uber forum lately. I used the cable recommended by 93turbod16 and it worked flawlessly and even came with drivers. He sais he has used numerous cables like them and never had any problems.
Old May 15, 2005 | 10:47 PM
No no, I'm talking about this:
https://honda-tech.com/zerothread?id=1245856
Old May 15, 2005 | 10:49 PM
civicdx1's Avatar
i put mine in it work fine with the basemap ,just the idle sometimes goes up and down.but i was told it should go away after a tune.
Old May 15, 2005 | 11:00 PM
Default Re: Uberdata users check in here! (civicdx1)
Yeah, idle goes funky sometimes.
To answer your question, I tuned my own car. It's cake. You just need a wideband + ostrich, but it still comes out cheaper than paying a tuner. I can't answer PMs because I'm a newb
Old May 15, 2005 | 11:13 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuagmireIII &raquo;</TD></TR><TR><TD CLASS="quote">No no, I'm talking about this:
https://honda-tech.com/zerothread?id=1245856</TD></TR></TABLE>
oops sorry man. I didn't even see the thread. Too bad you aren't a trial member or you could have pm'd me.
Old May 16, 2005 | 05:11 AM
93turbo16's Avatar
Here are a few problems, you can explore them further. Flucuating idle, little blips in the TPS, Ostrich works for most people, ost2 saves to big... just check out the uberdata site.
I have been using it forever, and have tuned many cars on it.. the more you do the more stuff you find. It is a great software, the link is in my sig for the site.
Old May 16, 2005 | 06:42 AM
Siguy00's Avatar
Im using uberdata on my Civic Si turbo set up and its working great! Im on uberdata 1.66 no codes. Best solution if you cant afford those standalone systems.
Old May 16, 2005 | 07:13 AM
King Tut33's Avatar
I have been experimenting with both Uberdata and Crome on my nearly stock Integra SE. I had no problem following the Uberdata instructions for making an LS base map and it runs great with no idle or performance issues. However, I have been unable to get a Crome chip to idle well on my car at all especially while cold. Normally the idle stays around 1500 - 2000 RPM and will sometimes fluctuate. I have tried both a stock LS P72 bin and made my own LS based P30 bin. I would have to say after looking at both so far that Uberdata would be the simpler choice.
Old May 16, 2005 | 07:47 AM
raene's Avatar
Been using Uberdata since version 1.2. I've had every problem under the sun, most of them my own fault. In general the software works very well but it's not something you should try if you want to set-it-and-forget-it
Old May 16, 2005 | 09:03 AM
blackeg's Avatar
Default Re: Uberdata users check in here! (raene)
currently using it on my second turbo setup.
first time around i had a problem with my chip burner, but that has since been repaired. i havent really had and serious running problems with it. my car runs smooth, starts up well and idles pretty normal for injectors 2x the size of stock. im running version 1.6666. i might upgrade to 1.7 and try to hook up the datalogging soon
Old May 16, 2005 | 09:05 AM
SOHC_MShue's Avatar
Default Re: Uberdata users check in here! (blackeg)
upgrade to 1.7 man . I don't know why some of you guys are still using 1.666
Old May 16, 2005 | 10:13 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">upgrade to 1.7 man . I don't know why some of you guys are still using 1.666 </TD></TR></TABLE>
hahaha, me either. guess i just figured that its working good so far, so why change it
Old May 16, 2005 | 10:14 AM
SOHC_MShue's Avatar
Yea the main reason i went to 1.7 was for closed loop disable and datalogging.
Old May 16, 2005 | 10:52 AM
raene's Avatar
1.66 has closed loop disable... also you need to retune to run 1.70+.
Old May 16, 2005 | 11:00 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">1.66 has closed loop disable... also you need to retune to run 1.70+. </TD></TR></TABLE>
i used cld on 1.666 and my car ran like complete crap, same setting and everything with 1.7, runs like a dream? I dunno. I am not a programmer and don't even try to be one, but 1.7 seems to work alot better than 1.66. imo
Old May 16, 2005 | 11:21 AM
raene's Avatar
Default Re: Uberdata users check in here! (mattssi)
You have to tune in either case... can't just check the box By default the maps are very rich, and 1.70 seems to run leaner than 1.66, so it makes sense that it would run better in 1.70 with CL Disable checked.
Old May 16, 2005 | 11:27 AM
VTC_CiViC's Avatar
Christ.. I don't even know which version I use anymore.
Old May 16, 2005 | 01:09 PM
Enzo Speed's Avatar
Default Re: Uberdata users check in here! (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Christ.. I don't even know which version I use anymore.</TD></TR></TABLE>
Lol - I've got every version imaginable scattered all over my desktop. I don't even know the official names of some of them.
Old May 16, 2005 | 01:26 PM
SOHC_MShue's Avatar
I only see disable o2 heater sensor. I'm not sure if that would do the same thing or not, but in 1.70 it has a check box for both. Anyways yea the car will run like complete **** if you don't tune the low vac maps after disabling closed loop. Most of the cars I tune seem to run between 10-12:1 through all the part throttle maps with closed loop disabled until i tune them.
vestalfootball72
Jan 16, 2008 11:25 AM
ek_ctr
Dec 30, 2006 11:14 PM
row1rich
Nov 28, 2006 07:53 PM
andysila
Dec 30, 2005 12:59 PM
chad
55
Aug 14, 2003 03:30 AM
