uberdata/ ecu chipping?????
The last 2 days i have been reading about uberdata and have decided to go down that road. So i take look-see at my ecu and...... looks to me like there is a chip already in there, so im thinking woo-hoo no soldering! well i want to make sure it is the correct chip and everything i need to uberdata is actualy there.
I checked out the site and it shows you how to do a p28. and i noticed some differences between theirs and mine. however mine is a pr4 used in a 92 cx with a b18b motor?
so is my ecu already to go using uberdata? or do i need to add things still?
from what i see on the p28 write up:
-my yellow box is good
-my blue box looks different
-inside the rex box i am missing a piece
if you have rom chip location there then you are ready to go. if not then you will have to add the rom whre the 27c256 location is
by rom chip you mean a chip burnt through uberdata?
what about my red box? c51 and c52, i need to put a 0.1µf ceramic disc capacitors, right?
here is the chipped p28:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">some pr4 come allready there to run the external rom. Just open yours up take pic and post up hre or on the uberdata forum.
i already did, that is my ecu in the first post.
Looks like you're ready to go. Some of the items are not required (used for noise filtering if I remember right). Burn a chip and off you go...
Nice to see people considering uberdata as a real alternative to expensive fuel management.
its good to have a good desoldering/soldering station not really complicated but it does help when you ahve good equipment. The chips and stuff can be found at many places. cost of supplies is under 15.00 bucks with zif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott - 93HB Si »</TD></TR><TR><TD CLASS="quote">
C51/52 are optional. 0.1uF cap.
How are they optional? I have seen that some sights don't do it and some do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Hondata used to come with them. Now they don't. It's just for noise filtering [I think]. If it makes you sleep better at night, put them in.</TD></TR></TABLE>
ok, well my ecu is obviously already chipped, and i dont hear any weird noises as of, so i will leave them out for now
thanks a lot guys.
thanks a lot guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Electronic noise, not audible noise, haha. But yeah, you should be fine leaving them out.</TD></TR></TABLE>
haha, ive only had one class that dealt with electronics, im retarded
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Need Money. »</TD></TR><TR><TD CLASS="quote">I wish uberdata and **** wasnt so confusing.
How could it be any more simple? Such is the nature of the beast, you can only simplify things so much before they are what they are.
If you're not a DIY sort of person, willing to do research and make mistakes here and there... uberdata isn't for you. Just as in learning anything, there are always mistakes to be made.
</TD></TR></TABLE>How could it be any more simple? Such is the nature of the beast, you can only simplify things so much before they are what they are.
überdata is not that confusing... introduction of any technical material can be hard to comprehend fully at first.
read the faq's and check out the forum... start with what you can understand and go from there. alot of the information can be overwhelming so dont push yourself if your not getting it in 10 minutes, take a break and return to your study when mello'd.
yea, i always stayed away from in becuse i though i wouldnt understand. But for some reason yesterday i started really reading up on it. today i have a chip burner in the mail and i understand how to make my own rom. its reallynot as hard as you would think.
sure it will take a while to get good at, but hey ill be boosted by next weekend with any luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">yea, i always stayed away from in becuse i though i wouldnt understand. But for some reason yesterday i started really reading up on it. today i have a chip burner in the mail and i understand how to make my own rom. its reallynot as hard as you would think.
Yeah, it really isn't hard. Also, if you poke around the uberdata forum you can probably find a basemap to suit your needs.
</TD></TR></TABLE>Yeah, it really isn't hard. Also, if you poke around the uberdata forum you can probably find a basemap to suit your needs.
I just got all my chipping supplies in the mail today! A buddy bought a burner so I should be running uberdata by monday. I don't expect it will be very tough to figure out any problems that a quick H-t search or some hard thinking can't fix.
Do the ZIF sockets with the little silver lever with the ball on the end fit? they are pretty bulky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 »</TD></TR><TR><TD CLASS="quote">
How are they optional? I have seen that some sights don't do it and some do.</TD></TR></TABLE>
I wouldn't consider them optional. They are called decoupling capacitors, and they filter the power supply to the gate and EPROM chips. They are also .01uf not the .1uf as stated before.
