uberdata-------cel-------can't pull code--------revlimit at ~3500
Old Oct 16, 2003 | 02:51 PM
  #26
baphomet's Avatar
Default Re: (falconGSR)
I emailed blake and asked him how much of a donation he would want to add 3 options to enable / disable injector test circuitry, Knock sensor, and PA sensor
Would you guys be interested in sharing the costs with me if he wants to do it?
It would remove the manual hex editing we have do do.
Old Oct 16, 2003 | 02:56 PM
  #27
toxicshit's Avatar
Default Re: (slashDEVslashNULL)
that would be greath then i can use uberdata on EDM ECU's i will sponsor blake if he wants to help us JDM / EDM guys (Y) !!!....
what about the ELD ??
Greetz Erwin.
Old Oct 16, 2003 | 02:58 PM
  #28
baphomet's Avatar
Default Re: (toxicshit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote">that would be greath then i can use uberdata on EDM ECU's i will sponsor blake if he wants to help us JDM / EDM guys (Y) !!!....
Greetz Erwin.</TD></TR></TABLE>
I am sorry, but what is ELD again ::noob::
Old Oct 16, 2003 | 03:06 PM
  #29
toxicshit's Avatar
ElectricalLoadDetector
  #30
baphomet's Avatar
thanks, Have you seen this http://www.nitroburn.com/pgmfi...mMaps
Old Oct 16, 2003 | 03:12 PM
  #31
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">I emailed blake and asked him how much of a donation he would want to add 3 options to enable / disable injector test circuitry, Knock sensor, and PA sensor
It would remove the manual hex editing we have do do.</TD></TR></TABLE>
i am not sure this is necessary. what about just using a JDM rom? it will have this stuff disabled...
Old Oct 16, 2003 | 03:15 PM
  #32
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
i am not sure this is necessary. what about just using a JDM rom? it will have this stuff disabled...</TD></TR></TABLE>
afaik, a jdm rom won't open up in uberdata - correct me if I'm wrong.
Old Oct 16, 2003 | 03:19 PM
  #33
raene's Avatar
I would be willing to donate for the addition of the sensor enable/disable options.
I'd like to know how much more I should donate for 3 bar support though Since he's already got 2 versions, he'd have to make another 2, it would almost be easier to just get ppl to donate for the full version with the added options. I doubt blake wants 4 versions of the code running around.
Old Oct 16, 2003 | 03:21 PM
  #34
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">thanks, Have you seen this http://www.nitroburn.com/pgmfi...mMaps</TD></TR></TABLE>
From this link, which ecu's address should I use to change the hex values on uberdata roms?
The addresses for knock etc are different for a p30 and p72 etc. from what I can tell.
edit: I guess the p72 ones since I believe that is what uberdata is based on.
Modified by slashDEVslashNULL at 5:41 PM 10/16/2003
Old Oct 16, 2003 | 03:30 PM
  #35
Mr. Softee's Avatar
taken off for u blakey!
sam
Old Oct 16, 2003 | 03:35 PM
  #36
Mr. Softee's Avatar
Default Re: (94goldjungsr)
from my nika blizzle:
bjjhwar43242: i think hes using the wrong rom
bakjhkwar32523: sounds like hes opening a stock p30 rom and it just wont work
blakjkwr21321: tel his bitch *** to just use the p72 bin and tune from there
Old Oct 16, 2003 | 03:52 PM
  #37
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">from my nika blizzle:
blakjkwr21321: tel his bitch *** to just use the p72 bin and tune from there</TD></TR></TABLE>
I tried all the bins that uberdata came with All with the same results. I posted this earlier, on page one.
Old Oct 16, 2003 | 03:53 PM
  #38
falcongsr's Avatar
What is this crap?
afaik, a jdm rom won't open up in uberdata - correct me if I'm wrong.</TD></TR></TABLE>
i thought i opened a jdm p72 bin in it.
i cant confirm now as i am under a deadline @ work
Old Oct 16, 2003 | 03:55 PM
  #39
baphomet's Avatar
i cant confirm now as i am under a deadline @ work </TD></TR></TABLE>
off to find one
Old Oct 16, 2003 | 04:38 PM
  #40
baphomet's Avatar
Arg, I can't find a jdm p72 rom to try, but check out this thread:
http://www.pgmfi.org/phorum/re..._4107
Old Oct 17, 2003 | 04:21 AM
  #41
toxicshit's Avatar
The jdm versions of the p30 and p28 doesent have the injector routine, i think..... maybe a jdm p72 work???
and
have found that the label_065F (p30usdm) is the label_063D in the p72....
and label_159A (p30usdm) is the label_153A in the p72....
maybe you can try some of that...
Modified by toxicshit at 2:40 PM 10/17/2003
Old Oct 17, 2003 | 05:39 AM
  #42
toxicshit's Avatar
okay info on the p30 EDM / UDM ECU..
6002 1bit Knock Sensor Enable 0xFF enables, 0x00 disables
6004 1bit Barometric Sensor Enable 0xFF enables, 0x00 disables
0652 3 Injector test bypass #1 Change to J label_065F (03 5F 06)
1580 3 Injector test bypass #2 Change to J label_159A (03 9A 15)
but the wiki of pgmfi says that
600B 1bit Electric Load Detector Enable 0xFF enables, 0x00 disables
but if you read this post http://pgmfi.org/phorum/read.p...=3652 you will see in the botom that darksmilie thinks it has something to do with IAVC and Not with the ELD.
we have almost everything. but we dont have the ELD for sure........
Greetz Erwin.
Old Oct 17, 2003 | 06:21 AM
  #43
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote">okay info on the p30 EDM / UDM ECU..
We need the addresses for a p72 rom, since that is what uberdata uses afaik
I got this email from larraw:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by larrow &raquo;</TD></TR><TR><TD CLASS="quote">take a look at the wili page... in the rom section you will find info about p72 roms...
in my post is the addres to disable the inject test..
you can use a usdm p72 with inject and ks disable and de car will run, but still have to disable the pa and the eld, but there is no info about how to at the moment...
you must use a hex edtitor and edit the bin... its easy...
the most important now is to disable the pa ,so the mil light will off....
i must take a time to search on the code...
the eld is a minor problem take a look at the wili page... in the rom section you will find info about p72 roms...
the eld is a minor problem </TD></TR></TABLE>
so we have some hope
Modified by slashDEVslashNULL at 8:03 AM 10/17/2003
Old Oct 17, 2003 | 01:04 PM
  #44
toxicshit's Avatar
i have talked about it with a Admin at pgmfi.org and he told me about the p72 base of uberdata ( i diddnt know that ) .
and he would help me if i had some questions.
so i will search some more and ask around and i wil get it working. :D for my setup.
ill keep you up te date..
Greetz Erwin
Old Oct 18, 2003 | 10:31 AM
  #45
baphomet's Avatar
Okay, I got a jdm p72 map, added boost, set rev limit, ftl, etc. Car starts, idles, and runs perfect.
I didn't mess with the fuel settings so it might be rich and the timing might be a bit advanced since afaik in jdm land they have higher octance than we do in the US. I haven't hooked up the wideband yet. Thats the good part.
The bad part is CEL, when I try to pull the code it won't give me one, but the SRS light blinks and stays on. So I figure it has something to do with airbags or something - looks like something else to look for in the hex editor.
At least its not limping, and I don't care about airbags, I just want the cel to go away.
rom269 you can get it here http://www.nitroburn.com/pgmfi...Codes
If anyone has anymore insight please post.
Old Oct 20, 2003 | 08:32 AM
  #46
falcongsr's Avatar
What is this crap?
i think there is a good explanation in the HElms manual of any obd1 car what the SRS light means
it probly is NOT an airbag issue. some codes are displayed on it also!
Old Oct 20, 2003 | 08:33 AM
  #47
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">i think there is a good explanation in the HElms manual of any obd1 car what the SRS light means
Anyone have an obd1 helms? - mine only covers 96-00.
Old Oct 20, 2003 | 10:13 AM
  #48
Mr. Softee's Avatar
i have it i will peep it at home.
sam
Old Oct 20, 2003 | 10:14 AM
  #49
Mr. Softee's Avatar
also the solid CEL light tells me something is still missing or falsely added into the rom that the ecu doesnt want.
Old Oct 22, 2003 | 09:00 AM
  #50
White Smoke's Avatar
i my honda
Global Mod
Take it to autozone to get un readable codes checked.
They will do it for FREE
