With Uberdata, can a Stock Honda MAP Sensor Read Boost?
like it says can a stock honda MAP sensor read boost with uberdata? if so how much? do i need to use a missing link or am i ok without one?
After .75 bar of boost (stock map sensor rating) the map sensor will still read fuel and timing values for .75 bar, so if it is rich enough you can run more boost while staying safe.
Like nvD said, richen up the last column and it will use that map for anything over 11.73psi
To answer the next question you might have, yes a 3bar GM map sensor will work and read up to 24-28 psi, but it idles like crap because of the sensor's vacuum readings. They're working on it, and hopefully will have it fixed soon.
Mr. Softee
Mar 25, 2003 07:29 PM
