Type-S Doesn't sound right.. Is it working?
Old Jun 8, 2008 | 11:01 AM
Powered By Garrett's Avatar
Default Type-S Doesn't sound right.. Is it working?
Every type-s i've heard is like a high-pitched noise, and mine sounds like, well, compressor surge (fluttering air, iirc). I'm 99% sure i have it hooked up right, a vaccume hose into the top (bigger) nipple, no? Please someone help!
Old Jun 8, 2008 | 03:46 PM
swappedcx's Avatar
Default Re: Type-S Doesn't sound right.. Is it working? (Powered By Garrett)
Try a different location in the IM for your vacuum. If not, make sure your valve is adjusted properly and not too tight.
Old Jun 8, 2008 | 04:13 PM
Default Re: Type-S Doesn't sound right.. Is it working? (swappedcx)
Ill try relocating vac. As far as valve, are you talking about the top one thats hard/soft? i tried all the way hard, all the way soft, and in the middle, all the same.
Old Jun 8, 2008 | 04:59 PM
swappedcx's Avatar
Yea the one on the top. I had a similar problem with mine and could not get it to blow off worth a damn. The vacuum location on the intake manifold wasn't strong enough from where I was pulling it from.
Old Jun 8, 2008 | 05:01 PM
i got everything running from the map sensor's line, ill try somewhere else.
Old Jun 8, 2008 | 06:08 PM
That was it!! Thanks man!!
76 camaro car
Oct 7, 2014 02:18 AM
Shaguar47
Aug 27, 2012 04:55 AM
DaX
Jun 4, 2004 09:19 AM
liquidxEG
May 25, 2004 12:03 PM
