Type-R head or B16 head?
Old Jun 20, 2005 | 05:48 PM
Sketch_hs's Avatar
Default Type-R head or B16 head?
So i bent valves and am just going to replace the entire head.
Which would you go for (i'm on a tight buget BTW)
Type-R head with no CAMs or cam caps for $400 OR
Replacement b16a head for $250 complete?
I was thinking of putting my b16a cams and cam caps in the type-r head (will they fit??!) and then selling the b16a head minus the cams and cam caps to recoupe some of the $$$
So would the Type-R head be worth it? I'm running a stock bottem end for now, gt28rs at only 5.8lbs, but i would like to be able to rev a little higher.
Also will my b16a intake manifold bolt up to the Type-R head? Will the Type-R head raise the compression on my b16a?
Thanks H-T
Old Jun 21, 2005 | 06:25 PM
Turbocivic94's Avatar
Default Re: Type-R head or B16 head? (Sketch_hs)
U cant just change over cam caps. I would just replace it with b16a
Old Jun 21, 2005 | 07:57 PM
Pondus's Avatar
B16 and Type-R head is the same head with some small differences in parts and finishing work. Go for the B16 head.
Old Jun 21, 2005 | 08:03 PM
Juggernaut 2's Avatar
Default Re: Type-R head or B16 head? (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">B16 and Type-R head is the same head with some small differences in parts and finishing work. Go for the B16 head.</TD></TR></TABLE>
Second that motion
Old Jun 22, 2005 | 09:57 AM
7k rdlne's Avatar
Default Re: Type-R head or B16 head? (Juggernaut 2)
why not replace the valves? this would be a good time for valve train upgrade
Old Jun 22, 2005 | 09:58 AM
7k rdlne's Avatar
Default Re: Type-R head or B16 head? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">U cant just change over cam caps.</TD></TR></TABLE>
correct
Old Jun 22, 2005 | 11:11 AM
rough_draft's Avatar
the type r had has a factory port and polish
Old Jun 22, 2005 | 05:54 PM
Pondus's Avatar
Default Re: (Lmaonade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmaonade &raquo;</TD></TR><TR><TD CLASS="quote">the type r had has a factory port and polish</TD></TR></TABLE>
Nope, just some bowl work to smooth things out in the transition to the valve seats and a better valve job.
Sketch_hs
22
Jun 22, 2005 04:25 PM
corgiat
Sep 9, 2003 12:17 AM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
vtec69
Mar 4, 2002 10:59 AM
