Which type of oil should I use???
Old Sep 24, 2001 | 05:52 PM
yoshe95si's Avatar
Default Which type of oil should I use???
Okay I know this is a dumb question. I've always been using 5W-30 Royal Purple Synthetic Oil. (That's stuff's the shiet!!!) But now that I got a turbo, should I use the same weight??? I hear lots of different stories from different people like synthetic is ok and not ok, or use 10W30 or 5W30. Which one should I use and why?!?!?!?!?!?!?
Old Sep 24, 2001 | 05:56 PM
DragII's Avatar
25 Year Member
Default Re: Which type of oil should I use??? (yoshe95si)
do a search
I use mobil 1
10w30
Old Sep 24, 2001 | 06:15 PM
Mikex25's Avatar
New User
Default Re: Which type of oil should I use??? (DragIIcivic)
Should you use synthetic or regular stuff?
Old Sep 24, 2001 | 06:50 PM
DragII's Avatar
25 Year Member
Default Re: Which type of oil should I use??? (Mikex25)
synthetic
Old Sep 24, 2001 | 06:59 PM
JM Performance's Avatar
I was told by someone pretty reputible (one of the head mechanics at one of the top shops in NYC) to use regular oil, because sythetic breaks down to quick. Is this bull, or does it have some merit behind it?
Old Sep 24, 2001 | 07:16 PM
spyder's Avatar
New User
Default Re: Which type of oil should I use??? (00SilverLS)
I personally use Valvoline Dura-blend, it's a mix of synthetic and conventional oil. There is some website somewhere that has a listing of all the specs of various oils (viscosity, flash point, ash content, resistance to sludging, etc...) and durablend was only bested by one other oil that was not being made any more...
Old Sep 24, 2001 | 07:20 PM
Mikex25's Avatar
New User
Default Re: Which type of oil should I use??? (spyder)
yea I am really confused now I get a lot of different opinion on synthetic or regualar stuff.
Old Sep 24, 2001 | 07:40 PM
spyder's Avatar
New User
I was confused on the same thing, that's one of the reasons I got the durablend, you get the best of both worlds.
Old Sep 25, 2001 | 04:07 AM
4dGSR at work's Avatar
yup it was explained to me that synth "thins out" higher hp but safer to use thick non synth oil.
in the summer use 20 50
winter 10 30
mobil1 20 50 synth will be good all around use and the 20 50 is what drag recommends too
Old Sep 25, 2001 | 04:26 AM
newsense's Avatar
New User
Default Re: Which type of oil should I use??? (4dGSR at work)
just my personal opinion....... castrol syntec blend 5w30
Old Sep 25, 2001 | 05:05 AM
RGAZ's Avatar
New User
Mobil 1 5W30.
The Twin turbo porsche comes with a case of Mobil 1 in the trunk with purchase.
nuff said.
Randy
Old Sep 25, 2001 | 06:24 AM
VTC_CiViC's Avatar
Default Re: Which type of oil should I use??? (RGAZ)
Heh, have you ever seen the little silver plaque on the motor itself Randy? You can see it when the wing is in the "up"' position on the Carrera's, it says in German to use Only Mobil 1, that says alot!
Old Sep 25, 2001 | 10:09 AM
RGAZ's Avatar
New User
Default Re: Which type of oil should I use??? (VTC_CiViC)
I haven't seen it, but I understand why the use it. Less coking, better heat resistance, lower coeff of friction.
All good stuff.
Randy
20ls01
Jul 4, 2007 10:19 PM
vtec25
Sep 3, 2006 11:10 AM
jh2586
Dec 7, 2005 10:20 AM
caliquick_teg
Dec 31, 2002 07:32 PM
Evil_Wizard
52
Oct 28, 2002 09:05 AM
