Two somewhat stupid questions...
Will you make something up for me please?
I have two questions for you guys. I already asked Tomakit, but I wanna hear some other answers why it wouldn't work.
1) I can see that EGT temps are somewhat related to the amount of boost that you're pushing. For example, if I boost hard at 5psi, I can do it for a pretty long time until my temps reach a certain number. Now if I boost at 10psi, the rate that it rises to the same temperature is much quicker...therefore I can't stay at boost for as long as I did at 5psi. Now my question is (I already know it's impossible, but why?) what's to stop someone from just setting their boost at 30psi or something and letting off when the temps reach a certain point? Doesn't the EGT tell you the condition of your motor?
2) Second stupid qustion...hehe. Forgive me guys. Another EGT related one too. Say I want to boost until 1300F to be safe. However, if my A/F gauge still shows a good mixture, can I keep boosting? Say I boost all the way until 1450F or so (the point where my friend says is too much) but my A/F shows good figures? Does it mean I'm still safe?
Okay guys, thanks. I finally got my turbo in working order....somewhat. Turns out the S-AFC was crapping out. Now I want to know how hard I can run my car. Thanks again.
using your EGT that heavily for information is a bad idea. To figure out what the maximum PSI you should be boosting, you must look at the fuel system you are running, and determine its limits within a reasonable amount, then DONT boost past that.
2) Unless you have a wide band O2 sensor, then I wouldn't rely on the A/F you have now. Its prolly just a single wire O2, right? Those things aren't as accurate as the EGT. The EGT being closer to the engine will be more accurate.
1) You prolly don't have the fuel for anything above what you are running now. Even at 10psi you said your temps are rising. Just from that it sounds like you're running lean and should rethink the 10psi setup.
How high should I run my EGTs? Right now I run to about 1300-1350F. However, I'm hearing some people on this board running as high as 1500F on a stock motor. As of right now, the temps on my car go to 1350F before I can complete a 1/4 mile run. Not tuned right? Or can I run higher? Thanks.
do you have access to a dyno?
then you dont have enough money to boost more than you are.
Tom
Tom
B00STED Si
Jan 15, 2005 05:27 PM
