two problems
Old Jun 26, 2003 | 10:20 PM
ludelvr's Avatar
Default two problems
Okay, the first problem I had was that my batt light came on while I was hard driving on the highway. It's an h22a and pretty much an fmax setup. The dumptube on my wastegate is a few inches away from my alternator and it's a short pipe so it may be releasing the gasses too close. Could too much heat cause the batt light to come on?
Second Q is that while driving, once the light came on, the clutch all of a sudden hit rock bottom, and I couldn't even step on it cuz i at was right to the floor and it wouldn't come back up. I was in 5th gear at a pretty high speed and it just wouldn't spring back up, until I put my foot under it and pulled it back up and then all was well again. I havea hydrolic clutch and ther was plenty of fluid when I stopped and checked but I'm baffled at why it would do this. I'm also wondering if these two misshaps are related
Old Jun 26, 2003 | 10:25 PM
I Like Boost's Avatar
Default Re: two problems (ludelvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludelvr &raquo;</TD></TR><TR><TD CLASS="quote">Okay, the first problem I had was that my batt light came on while I was hard driving on the highway. It's an h22a and pretty much an fmax setup. The dumptube on my wastegate is a few inches away from my alternator and it's a short pipe so it may be releasing the gasses too close. Could too much heat cause the batt light to come on?</TD></TR></TABLE>
This happened to me also on a 100mph+ joyride. ended up being that i broke my alternator belt. easy $10 fix. no idea on the 2nd question.
Old Jun 26, 2003 | 10:51 PM
ludelvr's Avatar
Default Re: two problems (IMPULSE B18C-T)
well, my belt is still working and still attached and it only did it under heavy driving and heavy acceleration. It's baffling the **** outta me!! haha
Old Jun 27, 2003 | 03:12 PM
ludelvr's Avatar
ttt
Old Jun 27, 2003 | 06:45 PM
TeStUdO's Avatar
maybe your belt is slipping during hard acceleration. check the belt for excessive wear/cracking
Old Jun 28, 2003 | 09:34 AM
scttydb411's Avatar
you have air in your clutch fluid now...probably boiled it if you are blowing exhaust on it or if dp is touching/really close to the bleeder valve. bleed while adding new fluid. happened to me while testing mine out running open dp. alternator could be overheating and causing to run inefficiently.
ctownintegra
Sep 28, 2006 07:12 PM
Wsteun
Jun 11, 2006 08:13 PM
Boring99'Accord
Mar 8, 2005 09:42 PM
B16aCRXSi
Jun 30, 2004 09:23 PM
spd18
Feb 25, 2003 04:59 PM
