TurboXS MBC question
Old Jan 25, 2002 | 07:52 AM
RAWB's Avatar
Default TurboXS MBC question
Is there a BIG difference between the Standard boost controller and the High Performance boost controller? I'm only going to boost a max of 10psi. TIA
Old Jan 25, 2002 | 08:38 AM
TurboITR's Avatar
Default Re: TurboXS MBC question (integracon)
i believe the high proformance will allow you to boost higher - I think the cut off on the standard is like 15-17psi
you should be fine with the standard at 10psi
Old Jan 25, 2002 | 07:45 PM
turbotypeR@SPEC's Avatar
25 Year Member
there is a huge difference.the high perf controller will allow you to build full boost until you reach your set boost pressure.it will spool much faster.
Old Feb 2, 2002 | 06:43 PM
RAWB's Avatar
Well I got it. Gotta say it does increase boost repsonse. I picked it up for $100 BRAND NEW shipped, not a bad deal. Also, I mounted it with my TIAL and ran into NO problems, like other members were having with this combo. Oh yeah, is heat a concern when dealing with the TurboXS? I wouldn't think so, cause everything is manual(Ball/Spring mechanism) I have it mounted just off the VTEC solenoid bracket.
ericstambaugh07
Jun 23, 2007 09:04 AM
1tyme
Nov 27, 2002 05:32 PM
echo999
Oct 3, 2002 07:41 PM
