Turboxs MBC isnt working...
Old Oct 26, 2001 | 05:46 PM
Etylorcen's Avatar
Default Turboxs MBC isnt working...
Im having trouble w/ my mbc. I have the vacuum line on the side of the mbc connected to the side of the wastegate which is connected to the turbo and the bottom vacuum line connected to the top of the wastegate. I turned the mbc's allen screw all the way clockwise (the direction of negative boost on the mbc) and I'm still hitting 12psi. No detonation or pinging but still I dont want to boost this much.
Old Oct 26, 2001 | 06:19 PM
GSR_Dude's Avatar
Default Re: Turboxs MBC isnt working... (Etylorcen)
I think you connect the side port of the MBC to the Turbo pressure hose and then connect the bottom of the MBC to the side port of the wastegate.
Old Oct 26, 2001 | 07:09 PM
Etylorcen's Avatar
Default Re: Turboxs MBC isnt working... (GSR_Dude)
Isnt the turbo pressure hose teh side port of the wastegate?
Old Oct 26, 2001 | 07:18 PM
Rob03Pro5's Avatar
whats the default psi on your wastegate?
Old Oct 26, 2001 | 07:20 PM
Etylorcen's Avatar
Default Re: Turboxs MBC isnt working... (Rob92SC)
Ben says its 10psi but I've hit 12 and then i let off. It pulls like hell though. 1st gear is pretty useless I lose traction when i hit full boost and im running on some heavy katana c5's w/ nitto 555's
Old Oct 27, 2001 | 09:20 AM
Mr. Vapor's Avatar
i have mine set up a bit differently.....i have the side of my Waste gate going to my MBC, then from the MBC it goes to my vac line on my intake manifold, the top port of my wastegate is left open, and mine controls boost. try it this way maybe?
Old Oct 27, 2001 | 09:28 AM
dustin's Avatar
Default Re: Turboxs MBC isnt working... (NYb16)
You have it hooked up wrong.
Unless you have an EBC, NEVER HOOK ANYTHING UP TO THE TOP PORT ON THE WASTEGATE.
The bottom port on the TurboXS goes to the side port on the wastegate, and the side port on the TurboXS goes to a STRONG manifold source. On tony's car, we used the brake booster line.
Dustin
Old Oct 27, 2001 | 10:19 AM
Etylorcen's Avatar
Default Re: Turboxs MBC isnt working... (dustin)
Thats how I had it and it didnt work, then Ben told me to do it the other way. Hmm ill try it again. Does the mbc only work if the screw is kinda loose? Cuz I tightened that thing all the way and still seeing lots of boost.
Old Oct 27, 2001 | 10:44 AM
dustin's Avatar
You cannot boost any lower than the spring in your wastegate.
Dustin
Old Oct 29, 2001 | 09:43 PM
Etylorcen's Avatar
I tried hooking it up to the manifold vacuum connected to the intake manifold and the valve cover and that didnt work. Where exactly is the brake booster? Its a b18b btw.
[Modified by Etylorcen, 6:43 AM 10/30/2001]
Old Oct 29, 2001 | 09:45 PM
Anthony K's Avatar
New User
Hey, I know that guy in that pic.
Old Oct 30, 2001 | 09:50 AM
98hx99b18c's Avatar
Why should you never hook anything up to the top port of the wastegate unless you're using an ebc?? Im using a turbonetics MBC and in the directions it shows to hook up the vacuum port to the top side of the wastegate, thats how I hooked it up.
Old Oct 30, 2001 | 05:15 PM
Anthony K's Avatar
New User
Default Re: Turboxs MBC isnt working... (98hx99b18c)
Thats an internal wastegate though on the instructions. I think having an external wastegate might make a difference. Not quite sure though.
Old Oct 30, 2001 | 06:23 PM
Etylorcen's Avatar
Default Re: Turboxs MBC isnt working... (Anthony K)
Anyone? Dustin? Oh yeah, turboxs's website says to hook the vacuum on the side of the wastegate to teh site of the mbc and the top of the wastegate to the bottom of the mbc.
[Modified by Etylorcen, 3:27 AM 10/31/2001]
Old Oct 30, 2001 | 09:58 PM
98hx99b18c's Avatar
Yes anyone know the exact answer, what difference does it really make?
Old Oct 31, 2001 | 03:33 PM
Etylorcen's Avatar
ttt
Old Oct 31, 2001 | 03:35 PM
dustin's Avatar
The controller will work backwards then. If you have equal pressure on the top and bottom of the wastegate diaphram you get infinite boost.
Dustin
Old Oct 31, 2001 | 05:00 PM
Etylorcen's Avatar
Ok i guess turboxs is wrong. Where was the brake booster line? I tried running t'ing it off to the vacuum line that connects from the manifold and the head but that didnt work either.
Old Oct 31, 2001 | 07:50 PM
dustin's Avatar
Default Re: Turboxs MBC isnt working... (rawdigga)
DUSTIN..... in that picture you posted. inline with the break vaccum line from the manifold it seems like there is another check valve in line with it ... i know the factory one is the grey one closest to the Master cylinder but whats the other one on the other end it seems like there is another check valve in the vaccum line.. is this true (look closely) if so whats the purpose of it..... the reason why i ask cause i want to know if its bad to have the master cylinder see "boost" ... thanks in advance.. -joe
That is just a vacuum tee The MC will not see boost, that is the point of the factory check valve...
Old Oct 31, 2001 | 08:04 PM
Anthony K's Avatar
New User
haha, yup just a big vacuum T
Old Nov 1, 2001 | 09:26 PM
Etylorcen's Avatar
I found the brake booster vacuum line...should it connect to the line before or after the check valve?
Old Nov 1, 2001 | 09:27 PM
dustin's Avatar
Before.
98integralsB18
Jul 25, 2009 07:29 AM
chriskey0829
Feb 1, 2006 07:10 PM
StockBlockRob
Jul 30, 2004 08:34 AM
FOrSfEd
May 17, 2004 10:13 PM
VanHonda
Jun 8, 2003 04:01 AM
