Turbosmart e-boost controller
Old Jan 31, 2005 | 08:58 AM
VTEC-dood's Avatar
Default Turbosmart e-boost controller
Anyone currently using this looks pretty sweat just wanted to know if it is easy to use? Also wanted to know any cons with it the pros look numerous just by the description and options it has.
Old Jan 31, 2005 | 11:32 AM
VTEC-dood's Avatar
Default Re: Turbosmart e-boost controller (VTEC-dood)
noone likes turbosmart????
Old Jan 31, 2005 | 12:10 PM
onefstek's Avatar
I like it but too expensive for me. im still using a mbc. 98ctr
Old Feb 1, 2005 | 05:20 AM
powerls's Avatar
I use it. And yes it is slighty more expensive then others. But for what you get, it is worth every penny. I installed it within an hour, had it tuned in less then 20 min. It is great.... 3 stages of boost control, adjustable wastegate sensitivity, audible warning, over boost shutdown, peak hold, 2 auxilary outputs, and it has the gate pressure feature.... the gate pressure feature is my favorite thing, it lets you by pass the wastegate for how every many PSI you want, so you essentially are controlling when the wastegate opens. You'll build boost quicker, have more power mid-range and you can completely eliminate all boost creep.
Old Feb 4, 2005 | 01:28 PM
IS3Fifty's Avatar
Default Re: (powerls)
whats the price range on it?
Old Feb 4, 2005 | 02:48 PM
drumking15's Avatar
430ish
dont forget it has gear dependent boost control...has anyone tried that feature out yet>?
Old Feb 6, 2005 | 08:06 PM
IS3Fifty's Avatar
Default Re: (drumking15)
holy **** 430!!! Ill stick to the MBC
Old Feb 7, 2005 | 04:30 AM
hondaapi's Avatar
Default Re: (Bar'dEK)
Here in Germany is a company that sells the turborsmart for 599Euro, that is 775Dollars. Grazy guys......
Old Feb 9, 2005 | 09:19 PM
downeyballz's Avatar
i was also thinking of buying one. it would fit in your gauge cluster perfectly. i have a del sol, and i though it would be great if i put it where the clock goes. turbosmart is also know for making good products.
Old Feb 9, 2005 | 10:31 PM
Jockobo's Avatar
Default Re: Turbosmart e-boost controller (downeyballz)
430 aint bad for a electronic boost controller...esp with all those nifty features...doesnt apexi's ebc go for $600-700?
Old Feb 10, 2005 | 07:57 AM
has anyone else used this before?
Old Feb 10, 2005 | 09:29 AM
buck02's Avatar
ive never used it but im a dealer for them and i have sold a few
Old Feb 10, 2005 | 02:51 PM
Default Re: Turbosmart e-boost controller (buck02)
what do you sell them for, i couldnt find it on you site
Old Feb 10, 2005 | 07:00 PM
buck02's Avatar
yes we need to finish the sight sorry
the h-t price is 411.75
thats the 40psi one the 60psi one is bit more
Old Feb 10, 2005 | 07:27 PM
thats a good price, will pm you soon about ordering
Old Feb 10, 2005 | 09:13 PM
drumking15's Avatar
avc-r's go for around 375 new...a lil bit cheaper than this ebc...but this is a guage and not a huge display...but personally id choose the avcr over this...
Old Feb 14, 2005 | 07:53 PM
has anyone used an e-boost before?
Old Feb 14, 2005 | 08:39 PM
LostSolVTEC's Avatar
Default Re: (downeyballz)
before i found a deal on the AVC-R, i was going to get the E-boost, I heard that the only problem with it is that the vacuum line on the back is just epoxied on and can snap off if you aren't careful, just something to look into. Other than that i have heard nothing but good things about it, i still may pick one up later on down the road
Old Feb 15, 2005 | 05:41 AM
powerls's Avatar
Default Re: (LostSolVTEC)
That was a problem with previous E-boosts. Mine is securely fastened to the back of the E-boost. As far as the AVC-R goes, it is a good piece. It is just to complicated to use, for example... to change boost levels on the AVC-R, you need to press 3 buttons I believe. To change boost on the E-Boost, you just press one button. The E-boost is so simply to use, but yet it has so many features.
Old Mar 14, 2005 | 09:31 PM
bump
DarryCar
Apr 18, 2012 03:27 PM
turbo sol
Feb 23, 2009 09:12 AM
avsrule414
Dec 10, 2005 09:07 AM
Racer X
Mar 27, 2003 01:07 PM
