Turbonetics Big Shaft Diameter
Old Dec 22, 2008 | 06:09 PM
ashb82's Avatar
Default Turbonetics Big Shaft Diameter
I am needing to rebuild a old turbonetics i have. It is smoking when i first start it up. I need to know if i have a standard shaft or a big shaft turbo. Does any one know how i can tell the differents between the two shafts.
Old Dec 22, 2008 | 09:21 PM
TheShodan's Avatar
Moderator
Default Re: Turbonetics Big Shaft Diameter
Only you can tell that once you've disassembled it. Get measurements and give Turbonetics a call.
Old Dec 23, 2008 | 04:08 AM
ashb82's Avatar
is garret t3/t4 a 10mm because a guy told me that the old turbonetics where the same as garrett.
Old Dec 23, 2008 | 07:24 AM
HiProfile's Avatar
IIRC the t04 center housings had either big or small shafts, but the t3 only had the small shaft - which is why the hybrid was possible. Turbonetics are generally modified Garretts.
R6E6I6D
Aug 23, 2005 10:50 PM
j-specB20sol
May 11, 2004 10:41 PM
Vtec92Civic
Dec 15, 2003 05:49 PM
AlphaKennyWun
Feb 16, 2002 09:52 AM
