turbols finally dyno'd!!!
At 11psi I'm at 267whp, 237tq. Running 9.5:1 Endyn pistons with a Cometic Headgasket. So my compression is pretty low. Tuned with Uberdata. I was pretty happy with the results, I'd like to see 300whp but unfortunately I decided to run stock rods so I don't want to press my luck. I had some mild headwork done and I making peak power at 7500rpm. Weird for a LS head I thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnah »</TD></TR><TR><TD CLASS="quote">At 11psi I'm at 267whp, 237tq. Running 9.5:1 Endyn pistons with a Cometic Headgasket. So my compression is pretty low. Tuned with Uberdata. I was pretty happy with the results, I'd like to see 300whp but unfortunately I decided to run stock rods so I don't want to press my luck. I had some mild headwork done and I making peak power at 7500rpm. Weird for a LS head I thought.
Cometic headgasket wont drop it down more than 9:1 compression. I don't know why u didnt just spend the extra buck and upgrade your rods when u already upgraded your pistons? Also, you are not giving your LS enough credit. Stock ls are capable of 300whp without breaking so I would turn up the boost to at least 14psi and shoot for 300 with proper tunning
</TD></TR></TABLE>Cometic headgasket wont drop it down more than 9:1 compression. I don't know why u didnt just spend the extra buck and upgrade your rods when u already upgraded your pistons? Also, you are not giving your LS enough credit. Stock ls are capable of 300whp without breaking so I would turn up the boost to at least 14psi and shoot for 300 with proper tunning
turn up the boost. Engines dont blow up from X amount of boost. They reach a sertain HP level before they cant handle anymore. Keep cranking up the boosting and tunning until you reach your goal. 300 is very doable. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnah »</TD></TR><TR><TD CLASS="quote">anyone pushing 300whp w/stock rods??</TD></TR></TABLE>
not me, but I have seen people on this board make well over 300WHP on stock internals and they have lasted jst fine till now
. It's really the tune and maintenance upkeep
BoostedCivicSedan is pushing over 300whp and 270ft-lbs with stock rods and ARP rod bolts.
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
I made 293 whp 230 something tq @13.5 lbs on a complety stock b18a1. It's runin great after 4 months and lots of passes at the track. id say turn it up some and you will diff make 300+. With a good safe tune itl be fine
donkiman
Sep 30, 2004 04:35 PM
. Congrats bro
. I wish I had that much WHP
