Turboing a B16a2
Old Jul 16, 2006 | 04:58 AM
WA1TNC's Avatar
Default Turboing a B16a2
Hi im new here just wanting to know whats a cheap way of doing this on a b16a gen 2 like what turbo choice manifold etc
Thanks
Old Jul 16, 2006 | 07:45 AM
jspec22's Avatar
Default Re: Turboing a B16a2 (WA1TNC)
There is no cheap way to get a turbo, all turbo setups will cost you money. Dont go the cheap route on anything
Old Jul 16, 2006 | 07:48 AM
acuteviet's Avatar
Cheapest way..! Start looking around for parts, this mean junk yard every weekend and awhole lot of time on ebay bidding (price?). Cheap but takes a long...time! If you have that 1g buy it from ebay, complete turbo kit set up. I did it before spend around $600 bucks and 5+ months for complete kit (diy). I do not want to do it that again, not worth time and the money you saved!!!
Modified by acuteviet at 9:00 AM 7/16/2006
Modified by acuteviet at 9:03 AM 7/16/2006
Old Jul 16, 2006 | 07:58 AM
RedR's Avatar
if its your daily driver and u dont have funds to do it right nor for eventual problems, stay way from boost until u can afford it.
Old Jul 16, 2006 | 02:09 PM
WA1TNC's Avatar
Yeah it's my daily driver how about those kits on ebay they come with mani turbo etc but can it work on a standard ecu?Oh yeah im also from New Zealand and we dont really have turbo kits and if we do it's more then the civics we drive lol
Old Jul 17, 2006 | 02:46 PM
acuteviet's Avatar
I suggest you buy the kit from ebay then! Yes, you can use the stock ecu but won't run as good. You need to do the following: chip ecu, upgrade injectors, walbro fuel pump, fmu, I might be missing something out...You don't have to do all those but it helps a lot! If you want to save money and don't upgrade all those, it least upgrade the FMU is a most or say good bye to your engine...
Old Jul 17, 2006 | 08:38 PM
BfromSD's Avatar
Default Re: (acuteviet)
if you dont have lots of money get a used supercharger it will run for a long long time with less problems than a turbo
Old Jul 18, 2006 | 09:59 PM
beroll_eg6's Avatar
my friend just threw low comp pistons with good tunning and hes running 18psi for 5 years now
Old Jul 19, 2006 | 05:40 AM
WA1TNC's Avatar
Sweet thanks for the info aye helps heaps as for the super charger (used)what will that be off? bolt on units that fit honda's are rare as over here new or used..is it true that the factory map sensor only lets you make like 6psi then cuts you?
Old Jul 19, 2006 | 10:08 AM
Han Solo's Avatar
Default Re: (WA1TNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WA1TNC &raquo;</TD></TR><TR><TD CLASS="quote">Sweet thanks for the info aye helps heaps as for the super charger (used)what will that be off? bolt on units that fit honda's are rare as over here new or used..is it true that the factory map sensor only lets you make like 6psi then cuts you?</TD></TR></TABLE> the factory Map sensor goes to ~10.62psi. imo dont just go around looking for something "cheap" get together a budget and asses your goals. then start researching dont just take whats available, wait for the kit you want, what size turbo, trim A/R etc. unless you know what u want ur probably gonna be disappointed
Old Jul 19, 2006 | 12:42 PM
95BlkGSR's Avatar
Default Re: Turboing a B16a2 (jspec22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspec22 &raquo;</TD></TR><TR><TD CLASS="quote">There is no cheap way to get a turbo, all turbo setups will cost you money. Dont go the cheap route on anything</TD></TR></TABLE>
do it right or do it twice
or three or four time
Damion20
Mar 3, 2015 10:07 AM
06CivicSi
Honda Civic (2006 - 2015)
Aug 26, 2008 02:48 PM
egbaby
Jan 7, 2008 08:34 PM
Jxi8s2k
Nov 8, 2006 05:01 PM
TurboEg
Aug 1, 2003 06:46 PM
