turboedit in a pm6 and vss/eld sensors
Old Aug 2, 2004 | 03:38 AM
therealtime's Avatar
Default turboedit in a pm6 and vss/eld sensors
can i use turboedit on a pm6 ecu to eliminate the need for vss and eld sensors?
Old Aug 2, 2004 | 05:42 AM
USDM 4G VTEC's Avatar
Default Re: turboedit in a pm6 and vss/eld sensors (therealtime)
vss is the sensor that tells the ecu how fast the car is going
u cant eliminate it, or u will trow a code
now, if u worried about the 112 mph fuel cutoff from a JDM ecu, yes turboedit does have an option to eliminate it
as far as the ELD, i dont know what u mean... unless u talking about the Electric Load Detector... theres no way to get rid of that.. is a very important sensor that will read any loads on ur electrical wiring, wich can save ur motor...
Old Aug 2, 2004 | 01:34 PM
i am talking about putting the 2nd gen crx pm6 ecu and distributor in a 1st gen crx (i need electronic advance instead of vacuum)
the 1st gen si does not have the VSS and i don't know if it has an ELD, but im not worried about using either one unless there is absolutely no way around it. i know that i can use the cluster out of an hf for the VSS, but if i can reprogram the ecu not to use it, then i will.
i am planning on using turboedit and a romulator to reprogram the ecu to accomodate larger injectors and a few pounds of boost, i would just as soon knock those sensors out without buying more crap.
Old Aug 2, 2004 | 02:53 PM
xenocron's Avatar
ELD wont do anything except make the ECU blink 20 times...dont even think it will throw a dash light.
I'm not sure about your VSS issue. Many people on homemadeturbo.com and http://www.pgmfi.org have converted up from DPFI to MPFI and use the PM6 ECU in older Gen CRXs.
Check around there for some better answers...but I think the simple answer to your question is YES
Lude81
Aug 21, 2012 09:14 PM
ItalynStylion
Dec 5, 2004 10:56 AM
vtec92lude
Oct 1, 2004 03:19 AM
86CRXSi
Jun 12, 2002 05:17 PM
